WMS Java Mapscript : msIO_getStdoutBufferBytes bug
Howard Butler
hobu at IASTATE.EDU
Wed Aug 9 09:51:09 EDT 2006
This is most likely a bug in the gdBuffer typemap
for Java MapScript. Please file a bug in buzilla
for the Java MapScript component with your
example and information.
Thanks
Howard
At 10:32 AM -0300 8/9/06, José Vilson de Mello de Farias wrote:
>This is a multi-part message in MIME format.
>--------------080606080700010905000906
>Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>Content-Transfer-Encoding: 8bit
>Greetings,
> I've compiled MapServer from the CVS HEAD 4.9-dev (2006-07-28) and I'm
>suposing the msIO_getStdoutBufferBytes is not working properly when used
>in Java Mapscript. I've written a very simple example to explain how it
>happens. Please take a look at it :
> public void doPost(HttpServletRequest req,
>HttpServletResponse resp) throws
>ServletException, IOExcept
> PrintWriter p = resp.getWriter();
> mapObj map = new mapObj("/home/maps/rs.wms.map");
> OWSRequest reqOWS = new OWSRequest();
> reqOWS.setParameter("SERVICE", "WMS");
> reqOWS.setParameter("VERSION", "1.1.0");
> reqOWS.setParameter("REQUEST", "GetCapabilities");
> mapscript.msIO_installStdoutToBuffer();
> map.OWSDispatch(reqOWS);
> String contentType = mapscript.msIO_stripStdoutBufferContentType();
> byte[] content = mapscript.msIO_getStdoutBufferBytes();
> p.print(new String(content));
>The "byte[] content" stores the result of
>msIO_stripStdoutBufferContentType and it has some garbage data at the
>end. After the > 0x3E we have an NL 0x0A and finally a EOF 0x00, BUT the
>content doesn't stop at this point, there are more data after the 0x00
>and the Java Mapscript can "see" it. That's a big problem, because when
>this "content" is returned, the resulting XML is corrupted. Please check
>this example bellow.
> 000018a0 20 20 20 20 20 20 20 20 20 3c 2f
>4c 65 67 65 6e | </Legen|
> 000018b0 64 55 52 4c 3e 0a 20 20 20 20 20
>20 20 20 3c 2f |dURL>. </|
> 000018c0 53 74 79 6c 65 3e 0a 20 20 20 20
>3c 2f 4c 61 79 |Style>. </Lay|
> 000018d0 65 72 3e 0a 20 20 3c 2f 4c 61 79
>65 72 3e 0a 3c |er>. </Layer>.<|
> 000018e0 2f 43 61 70 61 62 69 6c 69 74 79
>3e 0a 3c 2f 57 |/Capability>.</W|
> 000018f0 4d 54 5f 4d 53 5f 43 61 70 61 62
>69 6c 69 74 69 |MT_MS_Capabiliti|
> 00001900 65 73 3e 0a 00 14 00 00 00 14 00
>00 00 14 00 00 |es>.............|
> 00001910 00 14 00 00 00 14 00 00 00 14 00
>00 00 14 00 00 |................|
> 00001920 00 14 00 00 00 14 00 00 00 14 00
>00 00 14 00 |...............|
>Is it a known bug? I'm afraid this kind of garbage can produce
>undesirable effects in WMS support. For this simples example I can
>"manually" remove it but I'm not sure how to deal with it in other
>cases. I'll be greatful if you could give me some light.
>Best regards,
>*JosÈ Vilson de Mello de Farias*
>/Analista de Sistemas
>//SSE - SeguranÁa Pblica/
>*DÕGITRO TECNOLOGIA*
>*E-mail:* vilson.farias at digitro.com.br
><mailto:vilson.farias at digitro.com.br%20>
>*Messenger: *vilsonfarias at hotmail.com
>***Site:* www.digitro.com.br <http://www.digitro.com.br%20>
>Content-Type: text/html; charset=ISO-8859-1
>Content-Transfer-Encoding: 7bit
><!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
><html>
><head>
> <meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
> <title></title>
></head>
><body bgcolor="#ffffff" text="#000000">
><font size="-1"><font face="Verdana">Greetings,<br>
><br>
>I'm suposing the msIO_getStdoutBufferBytes is not working properly when
>used in Java Mapscript. I've written a very simple example to explain
>how it happens. Please take a look at it : <br>
><br>
></font></font>
><blockquote>
> <pre><font face="Lucida Console"
>size="-1"> public void
>ServletException, IOExcept</font></pre>
> <pre><font face="Lucida Console" size="-1"> {
> mapObj map = new
>mapObj("/home/maps/rs.wms.map");</font></pre>
>size="-1"> OWSRequest reqOWS =
>new OWSRequest();
> </font></pre>
>size="-1">
> </font></pre>
>size="-1"> String contentType
> p.print(new String(content));</font></pre>
> <pre><font face="Lucida Console" size="-1"> } </font></pre>
></blockquote>
><font face="Verdana" size="-1"><br>
>the content doesn't stop at this point, there are more data after the
>0x00 and the Java Mapscript can "see" it. That's a big problem, because
>when this "content" is returned, the resulting XML is corrupted. Please
>check this example bellow.</font><font size="-1"><font face="Verdana"><br>
></font></font><font size="-1"><font face="Verdana"><small><font
> face="Lucida Console"><br>
></font></small></font></font>
><blockquote>
> <pre>000018a0 20 20 20 20 20 20 20
>20 20 3c 2f 4c 65 67 65 6e
></Legen|
>|dURL>.
>|Style>. </Lay|
>61 79 65 72 3e 0a 3c |er>.
></Layer>.<|
>74 79 3e 0a 3c 2f 57
>|/Capability>.</W|
>61 62 69 6c 69 74 69 |MT_MS_Capabiliti|
>14 00 00 00 14 00 00 |es>.............|
>14 00 00 00 14 00 00 |................|
>14 00 00 00 14 00
>|...............|</pre>
></blockquote>
><small><font face="Verdana">Is it a known bug? I'm afraid this kind of
>garbage can produce undesirable effects in WMS support. For this
>simples example I can "manually" remove it but I'm not sure how to deal
>with it in other cases. I'll be greatful if you could give me some
>light.</font></small><br>
><br>
><br>
><font size="-1"><font face="Verdana">Best regards,</font></font><br>
><div class="moz-signature"><br>
>-- <br>
><meta content="text/html; charset=ISO-8859-1" http-equiv="content-type">
><title></title>
><font color="#000000" face="Verdana, Helvetica, Arial" size="1"><font
> color="#000000" size="2"><b>José Vilson
>de Mello de Farias</b> </font><br>
><font color="#606060"><i><big>Analista de Sistemas<br>
></big></i></font></font><i style="color: rgb(96, 96, 96);"><font
> size="-2">SSE - Segurança Pública</font></i><br>
><font color="#000000" face="Verdana, Helvetica, Arial" size="1"><br>
><font color="#000080"><b>DÍGITRO TECNOLOGIA</b></font><br>
><font color="#000000"><b>E-mail:</b> </font><a
>href="mailto:vilson.farias at digitro.com.br%20"><font
>color="#606060">vilson.farias at digitro.com.br</font></a><br>
></font><font color="#000000" face="Verdana, Helvetica, Arial" size="1"><font
> color="#000000"><b>Messenger: </b></font></font><font color="#000000"
> face="Verdana, Helvetica, Arial" size="1"><a
>color="#606060">vilsonfarias at hotmail.com</font></a></font><br>
>Arial" size="1"><!--<font color = #000000>
><b>ICQ:</b></font>
><font color = #000000> 11866179</font><br>
>!--><font
> color="#000000"><b></b></font><font color="#000000"><b>Site:</b></font>
><a href="http://www.digitro.com.br%20"><font
>color="#000000">www.digitro.com.br</font></a><a
> href="http://www.digitro.com.br%20"> </a></font>
></div>
></body>
></html>
>--------------080606080700010905000906--
