Mapserver as WMS: Query
SUBSCRIBE MAPSERVER-USERS Joe H. Smith
thip at AIT.AC.TH
Wed Aug 9 11:26:07 EDT 2006
Dear all,
I have the same problem. I followed the same manual:
http://mapserver.gis.umn.edu/docs/howto/wms_server but I could not make it
work. If anyone can query feature through WMS, please please help.
My map file is below.
LAYER
NAME Asia
DATA asia_bnd
DUMP TRUE
PROJECTION
#proj=latlong
"init=epsg:4326"
END
METADATA
"wms_title" "Asia" ##required
"wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326 EPSG:4031"
"wms_name" "Asia"
"wms_server_version" "1.3.0"
"gml_include_items" "all"
END
TYPE POLYGON
TRANSPARENCY 70
TEMPLATE "/data/maplab-2.2/AIT/asia.html"
HEADER "/data/maplab-2.2/AIT/asia_header.html"
FOOTER "/data/maplab-2.2/AIT/footer.html"
STATUS ON
CLASSITEM cntry_name
LABELITEM cntry_name
CLASS
NAME "Asia"
EXPRESSION /./
STYLE
OUTLINECOLOR 74 74 74
COLOR 192 207 203
END
END
END
Thanks,
Thip
Quoting "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA>:
> Luca,
> Try setting DUMP TRUE in the LAYER object?
> ..Tom
> -----Original Message-----
> From: UMN MapServer Users List on behalf of Luca Manganelli
> Sent: Wed 09-Aug-06 09:59
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Cc:
> Subject: [UMN_MAPSERVER-USERS] Mapserver as WMS: Query
> Hi,
> I'm trying to make QUERY via WMS working.
> In the guide from:
> there are three ways:
> # GetFeatureInfo: return info about feature(s) at a query (mouse
> click) location. MapServer supports 3 types of responses to this
> request:
> * Text/plain output with attribute info.
> * Text/html output using MapServer query templates specified in
> the CLASS template parameter. The MIME type returned by the Class
> templates defaults to text/html and can be controlled using the
> metadata "wms_feature_info_mime_type".
> * Gml features.
> well, in my map file I defined:
> LAYER
> NAME "trees"
> DATA "base/tree"
> METADATA
> "wms_title" "trees"
> END
> PROJECTION
> "init=epsg:26591"
> END
> TYPE LINE
> STATUS ON
> #TRANSPARENCY 50
> CLASS
> NAME "trees"
> STYLE
> COLOR 0 255 0
> END
> END
> TEMPLATE "tree.html"
> END
> the TEMPLATE "tree.html" contains:
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
> "http://www.w3.org/TR/html4/transitional.dtd">
> <html>
> <head>
> <title>MapServer Template Sample</title>
> </head>
> <body>
> <b>[cl]</b><br>
> id [TREE_ID] - type [TREE_TYP]
> </body>
> </html>
> but in my WFS client (arcmap) it doesn't return me any query result
> (but I see the layer)
> "Work only as many hours as you can be productive and only as many hours as
> you can sustain." - Kent Beck, in "Extreme Programming Explained"
> http://www.trapanator.com/blog
This mail sent through AIT WebMail : http://www.ait.ac.th/
