question on query
Manfred Meier
m.meier at SPIEKERMANN.DE
Thu Aug 10 11:54:49 EDT 2006
Hi Albert,
when I load the html code into the browser then I get javascript errors
(status line of internet explorer) because document.the_map and
document.mapserv are undefined. "document.the_map" is used in the
javascript function set_Mode which is called in the onload event.
Do you get these errors too?
Maybe they come only here because I opened the html code direct in the
browser.
Manfred
Albert Anderson schrieb:
> Hi Lawrence,
> I tried copying your code and changing out your information to fit
> mine. Its not working to well. My button isnt doing anything. Here is
> my html code. Maybe you can look at it? I dont know what I am doing.
> Thanks, Albert
> <!-- MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
