question on query
Albert Anderson
bart_doggers at YAHOO.COM
Thu Aug 10 12:01:02 EDT 2006
Hi Manfred Meier,
I dont know about the errors cause I do not for sure how to open the html code direct in the browser. I have javascript for panning arrows around the image that I couldnt get working.
For the go button to I have to set some sort of vaule to that? I dont kow.
Thanks,
Albert
Manfred Meier <m.meier at spiekermann.de> wrote: Hi Albert,
when I load the html code into the browser then I get javascript errors
(status line of internet explorer) because document.the_map and
document.mapserv are undefined. "document.the_map" is used in the
javascript function set_Mode which is called in the onload event.
Do you get these errors too?
Maybe they come only here because I opened the html code direct in the
browser.
Manfred
Albert Anderson schrieb:
> Hi Lawrence,
> I tried copying your code and changing out your information to fit
> mine. Its not working to well. My button isnt doing anything. Here is
> my html code. Maybe you can look at it? I dont know what I am doing.
> Thanks, Albert
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060810/faa7616b/attachment.html
