It ain't pretty but it works
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu Aug 10 14:07:15 EDT 2006
You've got the values you need in the select list so why not just do:
function ChangeMonth() {
var mon =
document.Month.Months.options[document.Month.Months.selectedIndex].value;
WindRoseWindow=window.open("",
"WindRose","toolbar=1,status=1,scrollbars=1,menubar=1,width=800,height=500,alwaysRaised=1,resizeable=1");
WindRoseWindow.moveTo(0,0);
WindRoseWindow.document.write('<table border="0" bgcolor="#FFD700"
width="100%"><tr><td colspan="2">');
WindRoseWindow.document.write('<b><center>Click on February Wind Rose
Graph to Zoom In</b></center>');
WindRoseWindow.document.write('</td></tr></table><table
width="100%"<tr><td>');
WindRoseWindow.document.write('<center><a
href="http://www.coaps.fsu.edu/gis/coastal/wind_climo/722110" + mon +
"A.gif"><img
src="http://www.coaps.fsu.edu/gis/coastal/wind_climo/722110" + mon +
"A.gif" height="180" width="240"/></a><br>All</center>');
WindRoseWindow.document.write('</td><td>');
"W.gif"><img
"W.gif" height="180" width="240"/></a><br>El Nino (Warm)</center>');
WindRoseWindow.document.write('</td></tr><tr><td>');
"N.gif"><img
"N.gif" height="180" width="240"/></a><br>Neutral</center>');
"C.gif"><img
"C.gif" height="180" width="240"/></a><br>La Nina (Cold)</center>');
WindRoseWindow.document.write('</td></tr></table><table width="100%"
bgcolor="#FFD700"><tr><td colspan="2">');
WindRoseWindow.document.write('<a
href="javascript:window.close();"><center><b>Close</b></center></a>');
WindRoseWindow.document.write('</td></tr></table>');
Steve
>>> Gary Watry <watry at steam.coaps.fsu.edu> 8/10/2006 10:30:03 AM >>>
Hi
The site is
http://gisdev.coaps.fsu.edu/httpdocs/windrose.php
It will run slow as it has not been moved to a production server
Click on "get Info From Map"
Click over red star (any one will do)
Select a month in drop-down list (any will do)
The issue is I had to repeat a block of code over and over again,
programming by brute force (does anyone know of a better way than
repeating the code in the
The other question is can I query a shapefile from a test box.
I want to be able to type in a USAFID number and have it zoom into that
location and then open the form without having to click on the map.
Any thoughts
Gary L. Watry
GIS Coordinator
Center for Ocean-Atmospheric Prediction Studies
FSU / COAPS
Johnson Building, RM 215
2035 East Paul Dirac Drive
Tallahassee, Florida 32306-2840
Phone (850) 645-7457
E-Mail: watry at coaps.fsu.edu
