question on query
Albert Anderson
bart_doggers at YAHOO.COM
Thu Aug 10 14:27:08 EDT 2006
Hi Manfred,
Thanks. I got my panning working. Thanks for explaining it. I think I understand it now that they all have to be one name. Thanks for your help. I am still working on the query.
Thanks,
Albert
Manfred Meier <m.meier at spiekermann.de> wrote: Hi Albert,
I copied your html code to my local server and use it for the template
in the mapfile.
The result is: the Map Tools, Map Layers, Reference Map, legend titles
appear. The icons for the radio buttons do not appear but that's no problem.
The map appears (with some data of mine). If I click on one of the map
tools, and then into the map, then their is the correct effect. The map
zooms in or out or recenters.
When I click on the corners of the map margin (for pan), then I get a
javascript error because "document.mapserv" is undefined.
When I click on the GO button (which took a time to find it) I get
another javascript error, because "document.corner" is undefined. In
Lawrence's source code you see that "Corner" is the name of a form.
Your go-Button is in the form "the_form".
Then I have changed "the_form" to "the_map" and i have changed "mapserv"
in "document.mapserv" to "the_map". Then i deleted the line
"document.the_map.mode[0].checked=true" because this has an error anywhere.
Now the pan functions on the corner of the image are working. Not
perfect but they do. They pan an zoom. But I think this a not a big
problem to solve.
I have changed the "document.corner" into document.the_map. So now the
Go button kind of works. It produces a fresh page.
And I have changed the [program] placeholders to my actual url because I
don't know where to set this value.
Try to do the changes and test every step.
I'm now out. Perhaps til tomorrow.
Manfred
Albert Anderson schrieb:
> Hi Manfred Meier,
> I dont know about the errors cause I do not for sure how to open the
> html code direct in the browser. I have javascript for panning arrows
> around the image that I couldnt get working.
> For the go button to I have to set some sort of vaule to that? I dont kow.
> Thanks,
> Albert
> Manfred Meier wrote:
> Hi Albert,
> when I load the html code into the browser then I get javascript errors
> (status line of internet explorer) because document.the_map and
> document.mapserv are undefined. "document.the_map" is used in the
> javascript function set_Mode which is called in the onload event.
> Do you get these errors too?
> Maybe they come only here because I opened the html code direct in the
> browser.
> Manfred
> > Hi Lawrence,
> > I tried copying your code and changing out your information to fit
> > mine. Its not working to well. My button isnt doing anything.
> Here is
> > my html code. Maybe you can look at it? I dont know what I am doing.
> > Thanks, Albert
> Yahoo! Messenger with Voice. Make PC-to-Phone Calls
> to the US (and 30+ countries) for 2�/min or less.
How low will we go? Check out Yahoo! Messengers low PC-to-Phone call rates.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060810/008f6bf1/attachment.html
