DEM to topographic contour lines
Zenon Panoussis
oracle at PROVOCATION.NET
Fri Aug 11 14:46:57 EDT 2006
Bruno Patini Furtado wrote:
> I need MapServer to display the topography of a terrain based on a DEM
> file (http://en.wikipedia.org/wiki/DEM). Is there any configuration
> out-of-the-box for example in the LAYER element of the Map file?
LAYER
NAME "ETOPO2"
TYPE RASTER
STATUS DEFAULT
DATA "/vol/gis/etopo2/etopo2.tif"
PROCESSING "DITHER=YES"
PROCESSING "SCALE=AUTO"
MINSCALE 5000000
CLASS
NAME "Elevation above 8000m"
EXPRESSION ([pixel]>=8000)
COLOR 98 0 0
END
CLASS
NAME "Elevation 7500-8000m"
EXPRESSION ([pixel]>=7500 AND [pixel]<8000)
COLOR 106 8 0
END
# and so on ad absurdum...
END
> It would be necessary to define specific ranges and for each one a
> particular color.
Yes, and you will then meet the woes of harmonic colour scales; it's
a bitch. http://www.colorbrewer.org/ might be of some help, but it
only produces relatively short ranges. There must be some tool around
that produces colour scales programmatically, but I haven't found it.
You might also want to avoid the format hell I went through a couple
of weeks ago by checking http://www.nabble.com/Raster-tiling-t1985377.html .
Z
