Detail displey when zoom in
Fawcett, David
David.Fawcett at STATE.MN.US
Mon Aug 14 09:28:33 EDT 2006
I would say that zoom is still meaningful in describing MapServer. When
you 'zoom', you either request a layer that shows more (or less) earth
area in your fixed-size map window.
Overviews do not relate directly to the map image being returned by
MapServer. They are used as part of a raster data source to help make
your application more efficient. An overview is useful when you have
images that have a high resolution and you want to use as a data layer
on a relatively low resolution map.
For example, if you have an air photo that is 1,000,000 x 1,000,000
pixels and you want to use it at full extent in your map image that is
100 x 100 pixels. Every time that you request a map image, MapServer or
one of it's components has to look at the big image and figure out what
color to make each of the pixels in the 100 x 100 pixel layer. That
takes a lot of processing.
Instead, you can pre-build overviews, either inside or outside of the
image file for your data layer. That way, when you request a map image
like above, MapServer (or OGR) can decide to just use the pre-built
overview.
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Bruno Patini Furtado
Sent: Monday, August 14, 2006 7:50 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Detail displey when zoom in
One thing that might help is knowing that the MapServer
terminology for zoom is Overviews as can be seen in
http://mapserver.gis.umn.edu/docs/howto/raster_data/#building-internal-o
verviews .
Also, the GDAL uses the same term in
http://www.gdal.org/gdaladdo.html where:
The gdaladdo utility can be used to build or rebuild overview
images for most supported file formats with one over several
downsampling algorithms.
On 8/13/06, Hooi <wchoonhooi at gmail.com> wrote:
I intend to do something like Google Local where when
user zoom in, he can see same area but more details. How can I achieve
this in Mapserver?
"Minds are like parachutes, they work best when open."
Software Developer
webpage: http://bpfurtado.net
software development blog: http://bpfurtado.livejournal.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060814/67717d3c/attachment.html
