Extent of several (500+) TIFF images
Curtis W. Ruck
ruckc at YAHOO.COM
Wed Aug 16 09:31:43 EDT 2006
use ogrinfo with the -so option
----- Original Message ----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Sent: Wednesday, August 16, 2006 8:03:44 AM
Subject: Re: [UMN_MAPSERVER-USERS] Extent of several (500+) TIFF images
Or you can use the -so option instead of -al
From: Bruno Patini Furtado <bpfurtado at GMAIL.COM>
Sent: Wednesday, August 16, 2006 7:30:27 AM
Subject: [UMN_MAPSERVER-USERS] Extent of several (500+) TIFF images
I'm using a layer of more than 500 tiff files containing DEM information of a great area. I have created a tile index of all these maps using the gdaltindex program to use as a layer in my mapfile. It generated a .shp file along with a .dbf as expected.
I'm having problems to find the proper EXTENT to my map file that will for the moment only use the layer described above. Is there any easy way to get full extent of these images or shapefile? The utility program gdalinfo gives me proper information to build the extent of a single raster file, but I'm not aware of a tool that gives this kind of information of a shape file.
I've tried to use OpenJUMP [http://openjump.org] to hover the mouse over the min and max points of the shapefile but I had no success using the coordinates it gave me.
Any suggestions?
"Minds are like parachutes, they work best when open."
Software Developer
webpage: http://bpfurtado.net
software development blog: http://bpfurtado.livejournal.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060816/083538e0/attachment.html
