Easy way to get standalone mapserver already compiled
M.L. Jackson
mljacks2 at HOTMAIL.COM
Wed Aug 16 12:12:33 EDT 2006
Thanks but I only have one mapscript application........lol.
>From: Vitor Buitoni <vitor.buitoni at DIGITRO.COM.BR>
>Reply-To: Vitor Buitoni <vitor.buitoni at DIGITRO.COM.BR>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Easy way to get standalone mapserver
>already compiled
>Date: Tue, 15 Aug 2006 15:26:36 -0300
>M.L. Jackson escreveu:
>>I downloaded MS4W before but I noticed that there was a lot of unneeded
>>programs included as well as an Apache server which was of no use to me.
>>I never explored the cgi-bin directory. After reading your reply and
>>looking in the cgi-bin directory, I found exactly what I needed.
>>I basically copied all of mapserver's dependent libraries (and I'm sure
>>some other unneeded dll files) from the cgi-bin directory into a system
>>folder. I made sure that Tomcat added this system folder to its library
>>path so that mapscript/mapserver could find the .dll files when needed.
>It's not a very good idea to copy the dll files to a system folder, since
>it might break things... The best thing to do would be to add the folder
>with the dll files to the PATH environment variable and tomcat library
>path. (-Djava.library.path)
>> I then copied the mapscript.jar file found in cgi-bin/mapscript/java
>>into my project's WEB-INF/lib directory. Because Tomcat is sometimes
>>flimsy, it would be a good idea to manually copy the mapscript.jar file to
>>your project's WEB-INF/lib directory within Tomcat and not depend upon
>>deployment necessarily doing the job correctly.
>If you put the mapscript.jar into your project's WEB-INF/lib directory,
>you'll only be able to have one webapp inside tomcat using mapscript. If
>you want to have more than one webapp using mapscript, you should put
>mapscript.jar into the tomcat's shared/lib directory.
>I recommend you take a look in this documentation:
>http://mapserver.gis.umn.edu/docs/howto/java_mapscript_Tomcat_55
>Vitor.
>>Well, not a very detailed write-up but due to time constraints it is the
>>best that I can do. Maybe someone can take this write-up and make it more
>>detailed and formal. If no one can, I can probably write it up at a later
>>date. By the way, I am using MyEclipse for my mapserver project
>>development.
>>Thanks, Jeff.
>>>From: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>>>Reply-To: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>>>already compiled
>>>Date: Fri, 11 Aug 2006 18:57:07 -0400
>>>Um, isn't that what MS4W is?
>>>I think the only thing it is missing for you would be a java servlet
>>>right? Tomcat or something? You can definitely start with MS4W and add
>>>configure that for your servlet...but I am no java guy so I am no precise
>>>help.
>>>If you do decide to use MS4W, maybe you could document your work and
>>>possibly contribute a java section to the readme for MS4W? (meaning what
>>>it took you to use the files in \ms4w\Apache\cgi-bin\mapscript\java\).
>>>jeff
>>>M.L. Jackson wrote:
>>>>What I am essentially looking for is a fully compiled distribution of
>>>>mapserver for Windows. Instead of having to compile the entire
>>>>mapserver source code, I would like to download a fully compiled package
>>>>with support for all the programming languages (in particular Java
>>>>mapscript) and all the essential supporting libraries for full
>>>>functionality plus wms support without the hassle. Am I asking for too
>>>>much? :-)
>>>>>From: "Rahkonen Jukka" <Jukka.Rahkonen at mmmtike.fi>
>>>>>To: "M.L. Jackson"
>>>>><mljacks2 at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
>>>>>Subject: RE: [UMN_MAPSERVER-USERS] Easy way to get standalone mapserver
>>>>>already compiled
>>>>>Date: Fri, 11 Aug 2006 23:31:54 +0300
>>>>>Hi,
>>>>>How about Mapserver included in the FW Tools set, could it be something
>>>>>close to what you are searching for?
>>>>>-Jukka Rahkonen-
>>>>>-----Original Message-----
>>>>>From: UMN MapServer Users List on behalf of M.L. Jackson
>>>>>Sent: Fri 11.8.2006 22:58
>>>>>Subject: [UMN_MAPSERVER-USERS] Easy way to get standalone mapserver
>>>>>already compiled
>>>>>Is there an easy way to get mapserver and all its supporting libraries
>>>>>in an
>>>>>already compiled package with nothing else included? I am having a
>>>>>headache
>>>>>trying to compile the source code. Thanks.
>>>Jeff McKenna
>>>DM Solutions Group Inc.
>>>http://www.dmsolutions.ca
>>_________________________________________________________________
>>Express yourself instantly with MSN Messenger! Download today - it's FREE!
>>http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
On the road to retirement? Check out MSN Life Events for advice on how to
get there! http://lifeevents.msn.com/category.aspx?cid=Retirement
