Easy way to get standalone mapserver already compiled
M.L. Jackson
mljacks2 at HOTMAIL.COM
Wed Aug 16 12:31:34 EDT 2006
To add to the previous email, the PATH variable is set to point to the
folder with the mapserver .dll files in it. I forgot to mention that part.
I also mentioned in the other email that the folder was added to the Tomcat
library path. The folder where the dll files are located is not the actual
system folder but a subdirectory of systems (C:\WINDOWS\SYSTEM\mapserver).
There should be no program that tries to access those files except for my
mapscript application. Since the library files are not just "floating
around" in the SYSTEM folder, it should not disrupt other applications. But
then again, I am not exactly a "systems" person.
>From: Vitor Buitoni <vitor.buitoni at DIGITRO.COM.BR>
>Reply-To: Vitor Buitoni <vitor.buitoni at DIGITRO.COM.BR>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Easy way to get standalone mapserver
>already compiled
>Date: Tue, 15 Aug 2006 15:26:36 -0300
>M.L. Jackson escreveu:
>>I downloaded MS4W before but I noticed that there was a lot of unneeded
>>programs included as well as an Apache server which was of no use to me.
>>I never explored the cgi-bin directory. After reading your reply and
>>looking in the cgi-bin directory, I found exactly what I needed.
>>I basically copied all of mapserver's dependent libraries (and I'm sure
>>some other unneeded dll files) from the cgi-bin directory into a system
>>folder. I made sure that Tomcat added this system folder to its library
>>path so that mapscript/mapserver could find the .dll files when needed.
>It's not a very good idea to copy the dll files to a system folder, since
>it might break things... The best thing to do would be to add the folder
>with the dll files to the PATH environment variable and tomcat library
>path. (-Djava.library.path)
>> I then copied the mapscript.jar file found in cgi-bin/mapscript/java
>>into my project's WEB-INF/lib directory. Because Tomcat is sometimes
>>flimsy, it would be a good idea to manually copy the mapscript.jar file to
>>your project's WEB-INF/lib directory within Tomcat and not depend upon
>>deployment necessarily doing the job correctly.
>If you put the mapscript.jar into your project's WEB-INF/lib directory,
>you'll only be able to have one webapp inside tomcat using mapscript. If
>you want to have more than one webapp using mapscript, you should put
>mapscript.jar into the tomcat's shared/lib directory.
>I recommend you take a look in this documentation:
>http://mapserver.gis.umn.edu/docs/howto/java_mapscript_Tomcat_55
>Vitor.
>>Well, not a very detailed write-up but due to time constraints it is the
>>best that I can do. Maybe someone can take this write-up and make it more
>>detailed and formal. If no one can, I can probably write it up at a later
>>date. By the way, I am using MyEclipse for my mapserver project
>>development.
>>Thanks, Jeff.
>>>From: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>>>Reply-To: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>>>already compiled
>>>Date: Fri, 11 Aug 2006 18:57:07 -0400
>>>Um, isn't that what MS4W is?
>>>I think the only thing it is missing for you would be a java servlet
>>>right? Tomcat or something? You can definitely start with MS4W and add
>>>configure that for your servlet...but I am no java guy so I am no precise
>>>help.
>>>If you do decide to use MS4W, maybe you could document your work and
>>>possibly contribute a java section to the readme for MS4W? (meaning what
>>>it took you to use the files in \ms4w\Apache\cgi-bin\mapscript\java\).
>>>jeff
>>>M.L. Jackson wrote:
>>>>What I am essentially looking for is a fully compiled distribution of
>>>>mapserver for Windows. Instead of having to compile the entire
>>>>mapserver source code, I would like to download a fully compiled package
>>>>with support for all the programming languages (in particular Java
>>>>mapscript) and all the essential supporting libraries for full
>>>>functionality plus wms support without the hassle. Am I asking for too
>>>>much? :-)
>>>>>From: "Rahkonen Jukka" <Jukka.Rahkonen at mmmtike.fi>
>>>>>To: "M.L. Jackson"
>>>>><mljacks2 at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
>>>>>Subject: RE: [UMN_MAPSERVER-USERS] Easy way to get standalone mapserver
>>>>>already compiled
>>>>>Date: Fri, 11 Aug 2006 23:31:54 +0300
>>>>>Hi,
>>>>>How about Mapserver included in the FW Tools set, could it be something
>>>>>close to what you are searching for?
>>>>>-Jukka Rahkonen-
>>>>>-----Original Message-----
>>>>>From: UMN MapServer Users List on behalf of M.L. Jackson
>>>>>Sent: Fri 11.8.2006 22:58
>>>>>Subject: [UMN_MAPSERVER-USERS] Easy way to get standalone mapserver
>>>>>already compiled
>>>>>Is there an easy way to get mapserver and all its supporting libraries
>>>>>in an
>>>>>already compiled package with nothing else included? I am having a
>>>>>headache
>>>>>trying to compile the source code. Thanks.
>>>Jeff McKenna
>>>DM Solutions Group Inc.
>>>http://www.dmsolutions.ca
>>_________________________________________________________________
>>Express yourself instantly with MSN Messenger! Download today - it's FREE!
>>http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
Dont just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
