SLD has no effect
Bjoern Platzen
bjoern.platzen at MOMATEC.DE
Thu Aug 17 05:21:30 EDT 2006
Hi List,
in the past two days I read a lot about not-working SLD's, but none of the
tipps I found could solve the problem for me.
As a first step I tried to change the symbol of a point-layer via SLD, but
even this did not work. It just has no effect if I specify an SLD through
the link. The map is always drawn in the way, that is specified in the
mapfile.
The mapserver supports WMS-Server and SLD, the SLD is accessible via HTTP,
the image, that should be used as the symbol is accessible as well.
So here's the Mapfile:
NAME gevis3
STATUS ON
SIZE 500 500
SYMBOLSET symbols/symbols.sym
FONTSET "/var/www/GevisWMS/font/font.list"
EXTENT 2499586 5620009 25126865 5633119
UNITS METERS
SHAPEPATH "mapdata"
TRANSPARENT on
IMAGETYPE png
RESOLUTION 72
PROJECTION
"init=epsg:31466"
END
WEB
TEMPLATE rahmen.html
MINSCALE 1000
MAXSCALE 200000
IMAGEPATH "/var/www/GevisWMS/tmp/"
IMAGEURL "tmp/"
METADATA
"wms_title" "GeoVip Mapserver"
"wms_onlineresource"
http://echo488.server4you.de/GevisWMS/mapserv.cgi?map=/var/www/GevisWMS/gevi
s3.map&"
"wms_srs" "EPSG:31466 EPSG:31467"
"wms_feature_mime_type" "application/vnd.ogc.gml"
"wms_extent" "2499586 5620009 2512686 5633119"
END
END
LAYER
NAME "Eventparkinfo_venues"
GROUP "EventparkinfoVenues"
METADATA
"wms_title" "Eventparkinfo_venues"
"wms_group_title" "EventparkinfoVenues"
"wms_srs" "EPSG:31466"
"wms_extent" "2504000 5625000 2509000 5630000"
END
TYPE Point
CONNECTIONTYPE postgis
CONNECTION "user=user dbname=db host=localhost options='-c
client_encoding=UTF8'"
DATA "geom from (SELECT oid as oid, point_geometry as geom FROM t_venues)
AS foo USING srid=31466"
STATUS ON
MINSCALE 1000
PROJECTION
"init=epsg:31466"
END
CLASS
STYLE
SYMBOL 45
END
END
END
END#MAPFILE
The Symbol-definition:
#45
SYMBOL
NAME 'chio'
TYPE PIXMAP
Image 'images/chio.png'
Transparent 63
END
... and the SLD:
<StyledLayerDescriptor version="1.0.0"
xmlns="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
<Name>Eventparkinfo_venues</Name>
<NamedLayer>
<UserStyle>
<FeatureTypeStyle>
<Rule>
<PointSymbolizer>
<Geometry>
<ogc:PropertyName>point_geometry</ogc:PropertyName>
</Geometry>
<Graphic>
<ExternalGraphic>
<OnlineResource
xlink:type="simple"
xlink:href="http://echo488.server4you.de/GevisWMS/symbols/images/airport_30.
png"/>
<Format>image/png</Format>
</ExternalGraphic>
<Size>10.0</Size>
</Graphic>
</PointSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
Last but not least, here is the Link:
s3.map&LAYERS=Eventparkinfo_venues&STYLES=&STYLE=Eventparkinfo_venues&SLD=ht
tp://echo488.server4you.de/GevisWMS/aixtra2.xml&WIDTH=500&FORMAT=image/png&R
EQUEST=GetMap&HEIGHT=500&SRS=EPSG:31466&VERSION=1.1.1&BBOX=2504000.0,5625000
.0,2509000.0,5630000.0&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=applicat
ion/vnd.ogc.se_xml&
As SLD seems to work with umn-mapserver for a lot of people out there, I
think, that I have messed up something, but I just don't see what...
Any help is highly appreciated.
Thanks in advance,
Bjoern
