line, cartoline antialiasing
Ken Boss
Ken.Boss at DNR.STATE.MN.US
Thu Aug 17 09:15:05 EDT 2006
Volkan--
I don't know anything about cartolines, but for regular line features
you can:
1) use a 24-bit output image type (IMAGEMODE RGB (or RGBA))
2) set TRANSPARENCY ALPHA in the layer using antialiased lines
3) set ANTIALIAS TRUE in the STYLE element of the CLASS with
antialiased lines
See http://article.gmane.org/gmane.comp.gis.mapserver.user/19421 for
example mapfile snippets.
HTH,
--Ken
>>> Volkan Ulukut <vulukut at TESCILTURK.COM> 8/17/2006 1:59 AM >>>
Hi List,
I've read about the antialiasing feature for lines but can't seem to
work it
on my mapserver. When I add "antialiasing true" parameter on the style
of
the class of line layer nothing changes it's still having bad sight as
seen
on the attachment
Here is the relevant part of the map file. I've tested with cartoline
symbol
and plain line without any symbol, same result
IMAGETYPE png
SYMBOL
NAME "cartoline"
TYPE cartoline
FILLED TRUE
LINECAP round #[butt|round|square|triangle]
LINEJOIN round #[round|miter|bevel]
LINEJOINMAXSIZE 3
END
LAYER
NAME "Antalya"
STATUS ON
TYPE LINE
CONNECTIONTYPE OGR
CONNECTION "antalya.ovf"
LABELITEM "adi"
GROUP "gantalya"
DATA "antalya"
LABELMAXSCALE 15000
MINSCALE 500
MAXSCALE 25000
METADATA
"queryable" "true"
"searchfield" "adi"
END
CLASS
STYLE
#SYMBOL 'cartoline'
COLOR 120 120 120
OUTLINECOLOR 254 254 254
WIDTH 7
MINSIZE 1
MAXSIZE 100
ANTIALIAS TRUE
END
LABEL
TYPE TRUETYPE
FONT "fritqat"
SIZE 7
MINSIZE 4
MAXSIZE 256
POSITION AUTO
OFFSET 0 0
ANGLE AUTO
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
ANTIALIAS TRUE
PARTIALS FALSE
FORCE FALSE
ENCODING "ISO-8859-9"
END
END
END
