line, cartoline antialiasing
    Volkan Ulukut
    vulukut at TESCILTURK.COM
    Thu Aug 17 22:57:52 PDT 2006
That worked thanks. I wasn't using png24 as outputformat. But now I got a
problem with ka-map and png24.. well that's not the concern of this list
thanks!
-----Original Message-----
From: Ken Boss [mailto:Ken.Boss at DNR.STATE.MN.US]
Sent: Thursday, August 17, 2006 4:15 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] line, cartoline antialiasing
Volkan--
I don't know anything about cartolines, but for regular line features
you can:
1) use a 24-bit output image type (IMAGEMODE RGB (or RGBA))
2) set TRANSPARENCY ALPHA in the layer using antialiased lines
3) set ANTIALIAS TRUE in the STYLE element of the CLASS with
antialiased lines
See http://article.gmane.org/gmane.comp.gis.mapserver.user/19421 for
example mapfile snippets.
HTH,
--Ken
>>> Volkan Ulukut <vulukut at TESCILTURK.COM> 8/17/2006 1:59 AM >>>
Hi List,
I've read about the antialiasing feature for lines but can't seem to
work it
on my mapserver. When I add "antialiasing true" parameter on the style
of
the class of line layer nothing changes it's still having bad sight as
seen
on the attachment
Here is the relevant part of the map file. I've tested with cartoline
symbol
and plain line without any symbol, same result
IMAGETYPE png
SYMBOL
  NAME "cartoline"
  TYPE cartoline
  FILLED TRUE
  LINECAP round #[butt|round|square|triangle]
  LINEJOIN round #[round|miter|bevel]
  LINEJOINMAXSIZE 3
END
LAYER
    NAME "Antalya"
    STATUS ON
    TYPE LINE
    CONNECTIONTYPE OGR
    CONNECTION "antalya.ovf"
    LABELITEM "adi"
    GROUP "gantalya"
    DATA "antalya"
	  LABELMAXSCALE 15000
    MINSCALE 500
  MAXSCALE 25000
   METADATA
     "queryable" "true"
     "searchfield" "adi"
   END
     CLASS
	  STYLE
        #SYMBOL 'cartoline'
        COLOR 120 120 120
        OUTLINECOLOR 254 254 254
        WIDTH 7
        MINSIZE 1
        MAXSIZE 100
	  ANTIALIAS TRUE
        END
     LABEL
        TYPE TRUETYPE
        FONT "fritqat"
        SIZE 7
        MINSIZE 4
        MAXSIZE 256
        POSITION AUTO
        OFFSET 0 0
        ANGLE AUTO
        BUFFER 0
        MINDISTANCE -1
        MINFEATURESIZE -1
        COLOR 0 0 0
        ANTIALIAS TRUE
        PARTIALS FALSE
        FORCE FALSE
	  ENCODING "ISO-8859-9"
      END
   END
END
More information about the MapServer-users
