Using COLORRANGE to display DEM data
Frank Warmerdam
warmerdam at POBOX.COM
Fri Aug 18 00:06:10 EDT 2006
Jeff Hoffmann wrote:
> I'm trying to use the COLORRANGE feature to display DEM data, but I'm
> not getting any output from what I'm doing now. I have a tif with one
> band (the elevation) and I'm trying to first split that band into
> different classes for elevation ranges then I want to use a color ramp
> within each class to get a smooth blue->green->yellow->red sort of
> transition. The first split into classes seems to work -- I can assign
> each class a solid color and I'll see that, I just can't get the color
> ramp to work within the class. Here's one of my class definitions:
> CLASS
> EXPRESSION ([pixel] >= 500 AND [pixel] < 1000)
> STYLE
> COLORRANGE 48 255 180 255 255 0
> DATARANGE 500 1000
> RANGEITEM "[pixel]"
> END
> END
> Does anybody know what's going wrong here?
Jeff,
Excellent idea, but unfortunately the raster colorrange support only
works with one class, and a single color range. This is a limitation
of the implementation.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
