Mapscript php projection problems
Sven Borgers
Sven.Borgers at KINEOINTERACTIVE.COM
Fri Aug 18 06:16:11 EDT 2006
Hi!
I'm having a problem with projection in mapscript. I am working on an
application where I need to translate screen pixel xy coordinates to
latlon. The basic mapserver template variables give me the correct
result, I can replicate that result with cs2cs but have so far not been
able to get that out of the mapscript php project function. Any pointers
would be greatly appreciated.
I have a very simple mapfile with following projection spec and no
projection in the layers:
PROJECTION
"proj=tmerc"
"lat_0=49.000000000"
"lon_0=-2.000000000"
"k=0.999601"
"x_0=400000.000"
"y_0=-100000.000"
"ellps=airy"
"towgs84=375,-111,431,0,0,0,0"
END
When I use the mapserver application to find the latlon for:
x : 533604.343541
y: 180566.045573
The mapserver template MAPLAT, MAPLON variables return:
Lat: -0.076218
Lon: 51.508185
Which, when I look them up on MapQuest put me on the right spot.
When I use the command line proj4 applications I get following results:
invproj -f "%.6f" +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.999601
+x_0=400000 +y_0=-100000 +ellps=airy +towgs84=375,-111,431,0,0,0,0 <<EOF
> 533604.343541 180566.045573
> EOF
Lat: -0.074626
Lon: 51.507727
Which is not exactly the same point.
When I use the cs2cs command I get following result:
cs2cs -f "%.6f" +proj=tmerc +lat_0=49 +lon_0=-2 +k=0.999601 +x_0=400000
+y_0=-100000 +ellps=airy +towgs84=375,-111,431,0,0,0,0 +to +proj=latlong
+ellps=WGS84 +datum=WGS84 <<EOF
> EOF
Lat: -0.076218
Lon: 51.508185 45.074824
Which is what I would like to find
When I use Mapscript PHP:
$projInObj = ms_newProjectionObj( "proj=tmerc,".
"lat_0=49,".
"lon_0=-2,".
"k=0.999601,".
"x_0=400000,".
"y_0=-100000,".
"ellps=airy,".
"towgs84=375,-111,431,0,0,0,0");
$projOutObj = ms_newProjectionObj("proj=latlong, ellps=WGS84,
datum=WGS84");
$poPoint = ms_newPointObj();
$poPoint->setXY($_REQUEST["lon"],$_REQUEST["lat"]);
$poPoint->project($projInObj, $projOutObj);
I get:
Lat: -0.074619464992752
Lon: 51.505774438372
Which is close but still about 1km out of where it should land.
Sven Borgers.
