Dlls not found?
Eijnden, Bart van den (AGI)
b.vdeijnden at AGI.RWS.MINVENW.NL
Fri Aug 18 10:51:05 EDT 2006
Did you restart your machine after adding that directory to the PATH?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens robert fritz
Verzonden: vrijdag 18 augustus 2006 14:37
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Dlls not found?
Hello,
I 'm using mapserver as php-mapscript module on Windows XP with the IIS. All additional dll files for the mapserver are stored in a separate folder, the folder is included in the windows-system-search path.
On one XP machine everything works fine, on another XP machine, mapscript does not find the dlls. The dll-files in the folder are accessible from the command line - but obviously not for mapscript or php. Copying all dlls in the windows\system32 folder solves the problem, but I want the dlls in a separate folder. I'm logged in as Administrator on both machines.
phpinfo() shows the complete windows-search-path on both machines, therer are no differences between the installation of php or IIS. What can I do?
regards,
Robert
______________________________________________________________
Verschicken Sie romantische, coole und witzige Bilder per SMS!
Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
