Dlls not found?
robert fritz
robert-fritz at WEB.DE
Fri Aug 18 11:01:38 EDT 2006
Hello Bart,
yes, i restarted more the once:-). The dlls are accessible from the DOS command line. Maybe the problem is caused by security settings of XP? One XP machine is not updated regularly , but SP2 is installed on both machines.
nice weekend,
robert
Did you restart your machine after adding that directory to the PATH?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens robert fritz
Verzonden: vrijdag 18 augustus 2006 14:37
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Dlls not found?
Hello,
I 'm using mapserver as php-mapscript module on Windows XP with the IIS. All additional dll files for the mapserver are stored in a separate folder, the folder is included in the windows-system-search path.
On one XP machine everything works fine, on another XP machine, mapscript does not find the dlls. The dll-files in the folder are accessible from the command line - but obviously not for mapscript or php. Copying all dlls in the windows\system32 folder solves the problem, but I want the dlls in a separate folder. I'm logged in as Administrator on both machines.
phpinfo() shows the complete windows-search-path on both machines, therer are no differences between the installation of php or IIS. What can I do?
regards,
Robert
______________________________________________________________
Verschicken Sie romantische, coole und witzige Bilder per SMS!
Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
