Dlls not found?
Fortin,Nicolas [SteFoy]
nicolas.fortin at EC.GC.CA
Fri Aug 18 11:22:58 EDT 2006
Hi
As Bart said, you have to restart the pc for the PATH to reset, not just IIS.
If this didn't work, run filemon (http://www.sysinternals.com/Utilities/Filemon.html) while trying to acces the dlls via php and check for any ACCESS DENIED message as I think it's a permission issue (IUSR_[MACHINENAME] should have acces to the folder where the dll are in).
Hope this help,
Nicolas
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de robert fritz
Envoyé : 18 août 2006 08:37
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Dlls not found?
Hello,
I 'm using mapserver as php-mapscript module on Windows XP with the IIS. All additional dll files for the mapserver are stored in a separate folder, the folder is included in the windows-system-search path.
On one XP machine everything works fine, on another XP machine, mapscript does not find the dlls. The dll-files in the folder are accessible from the command line - but obviously not for mapscript or php. Copying all dlls in the windows\system32 folder solves the problem, but I want the dlls in a separate folder. I'm logged in as Administrator on both machines.
phpinfo() shows the complete windows-search-path on both machines, therer are no differences between the installation of php or IIS. What can I do?
regards,
Robert
______________________________________________________________
Verschicken Sie romantische, coole und witzige Bilder per SMS!
Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
