using OGR to connect MySQL
Fawcett, David
David.Fawcett at STATE.MN.US
Mon Aug 21 09:56:55 EDT 2006
Murat,
The MySQL direct connect functionality is relatively new to OGR. You
will need a relatively recent release of OGR, particularly if you are
running Linux. You will then need to re-compile MapServer with the new
OGR.
Based on your error message, it doesn't appear that you have a version
of OGR that supports direct connections to MySQL.
On somewhat older versions, you can set up a ODBC connection to MySQL
and then use OGR to connect to that, but I don't see ODBC support listed
in your error message either.
Essentially, you will need a newer version of OGR/MapServer.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Murat BEYHAN
Sent: Monday, August 21, 2006 7:42 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] using OGR to connect MySQL
Dear Friends,
I'm trying to connect MySQL database to draw earthquake epicenters on
the map that the data are stored in mysql like
ID, Latitude, Longitude, magnitude
1 30 40 3.5
2 31 41 5.5
I have tried to test ogr with the following command as explaeined in the
Document on Webpages' Mapserver.
ogrinfo /var/www/html/map/agidata.ovf
The agidata.ovf file is as follow.
<OGRVRTDataSource>
<OGRVRTLayer name="aqidata">
<SrcDataSource>MYSQL:eqinfo,user=root,password=mysql_123,host=localhost,
port=3306,tables=deneme</SrcDataSource>
<SrcSQL>SELECT ID,Lat,Lon,Mag FROM deneme</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="lat" y="lon"/>
</OGRVRTLayer>
</OGRVRTDataSource>
But I haven't achieved. The following messages is appearing on the
screen.
[murat at sakura mapdata]$ ogrinfo /var/www/html/map/agidata.ovf ERROR 1:
Unable to create Xerces C++ based GML reader, Xerces support not
configured into GDAL/OGR. ERROR 1: File /var/www/html/map/agidata.ovf
appears to be GML but the GML reader can't be instantiated, likely
because Xerces support wasn't configured in.
FAILURE:
Unable to open datasource `/var/www/html/map/agidata.ovf' with the
following drivers.
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> IHO S-57 (ENC)
-> MapInfo File
-> DGN
-> GML
-> AVCBin
-> REC
-> Memory
-> PostgreSQL
How can I fix this problem...
Thank You....
Murat
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
