layer configuration for WMS
Zenon Panoussis
oracle at PROVOCATION.NET
Mon Aug 21 19:35:15 EDT 2006
xslove wrote:
> Only one thing happened when I call request within browser. Within tmp
> folder (as it is specified by IMAGEPATH and IMAGEURL) is created empty file
> like as 115618998219400.img.tmp (where size is 0 bytes).
With the last map file it should be called TEST[long number].png,
but perhaps this is some intermediate file.
Your latest map file said
>> IMAGEPATH "/tmp/"
>> IMAGEURL "/tmp/"
and that's why I was asking about your filesystem paths. As I wrote
earlier in this thread,
>> The imagepath is relevant to your file system, the imageurl to
>> the webserver's document root. Try (adjusting to your system)
>> IMAGEPATH "/var/www/html/tmp/"
>> IMAGEURL "/tmp/"
so if your imageurl is /tmp/ and your imagepath is /tmp/ too, then
your webserver document root would be / on the file system, which
I doubt it is.
> After about two days I try it on linux system and we will see...
??!! Indeed, looking back, you said you're using windows already
a few postings back. I missed it, so I've been assuming linux all
along. Everything I've said so far is based on that wrong assumption.
I'm afraid I don't have windows, so I can't try it out on it.
Z
