layer configuration for WMS
xslove
xslove at CENTRUM.CZ
Tue Aug 22 04:00:46 EDT 2006
In fact I use no web server, I try it all on local at home with Apache
Tomcat, so I don't know what to write to IMAGEPATH.
Zenon Panoussis wrote:
> xslove wrote:
>> Only one thing happened when I call request within browser. Within tmp
>> folder (as it is specified by IMAGEPATH and IMAGEURL) is created empty
>> file
>> like as 115618998219400.img.tmp (where size is 0 bytes).
> With the last map file it should be called TEST[long number].png,
> but perhaps this is some intermediate file.
> Your latest map file said
>>> IMAGEPATH "/tmp/"
>>> IMAGEURL "/tmp/"
> and that's why I was asking about your filesystem paths. As I wrote
> earlier in this thread,
>>> The imagepath is relevant to your file system, the imageurl to
>>> the webserver's document root. Try (adjusting to your system)
>>> IMAGEPATH "/var/www/html/tmp/"
>>> IMAGEURL "/tmp/"
> so if your imageurl is /tmp/ and your imagepath is /tmp/ too, then
> your webserver document root would be / on the file system, which
> I doubt it is.
>> After about two days I try it on linux system and we will see...
> ??!! Indeed, looking back, you said you're using windows already
> a few postings back. I missed it, so I've been assuming linux all
> along. Everything I've said so far is based on that wrong assumption.
> I'm afraid I don't have windows, so I can't try it out on it.
> Z
View this message in context: http://www.nabble.com/layer-configuration-for-WMS-tf2133082.html#a5921112
Sent from the Mapserver - User forum at Nabble.com.
