layer configuration for WMS
Jacolin Yves
yjacolin at FREE.FR
Tue Aug 22 04:07:02 EDT 2006
You can try the path where you created your tmp directory.
Regards,
Y.
Le Mardi 22 Août 2006 10:00, xslove a écrit :
> In fact I use no web server, I try it all on local at home with Apache
> Tomcat, so I don't know what to write to IMAGEPATH.
> Zenon Panoussis wrote:
> > xslove wrote:
> >> Only one thing happened when I call request within browser. Within tmp
> >> folder (as it is specified by IMAGEPATH and IMAGEURL) is created empty
> >> file
> >> like as 115618998219400.img.tmp (where size is 0 bytes).
> > With the last map file it should be called TEST[long number].png,
> > but perhaps this is some intermediate file.
> > Your latest map file said
> >>> IMAGEPATH "/tmp/"
> >>> IMAGEURL "/tmp/"
> > and that's why I was asking about your filesystem paths. As I wrote
> > earlier in this thread,
> >>> The imagepath is relevant to your file system, the imageurl to
> >>> the webserver's document root. Try (adjusting to your system)
> >>> IMAGEPATH "/var/www/html/tmp/"
> >>> IMAGEURL "/tmp/"
> > so if your imageurl is /tmp/ and your imagepath is /tmp/ too, then
> > your webserver document root would be / on the file system, which
> > I doubt it is.
> >> After about two days I try it on linux system and we will see...
> > ??!! Indeed, looking back, you said you're using windows already
> > a few postings back. I missed it, so I've been assuming linux all
> > along. Everything I've said so far is based on that wrong assumption.
> > I'm afraid I don't have windows, so I can't try it out on it.
> > Z
Yves Jacolin
http://yjacolin.gloobe.org
Stagiaire Conservatoire Régional des Espaces Naturels de la région Centre
http://cahiersnaturalistes.free.fr/cpnrc/
- Qu'est-ce que cela peut faire que je lutte pour la mauvaise cause
puisque je suis de bonne foi?
- Et qu'est-ce que ça peut faire que je sois de mauvaise foi
puisque c'est pour la bonne cause. (Jacques Prévert)
