Mapscript Re-Projection on-the-fly
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Thu Aug 24 01:59:07 EDT 2006
Stefan,
Your question is not entirely clear. You can not re-project an
individual layer on-the-fly, because php_mapscript does not re-write the
dataset (hence its projection will always be the same); you CAN however
change the projection of the map (using setProjection, as you did),
which means all layers in the map get re-projected (the dataset remains
unchanged, though). For this, it is required that your layer has a
projection object with the native projection of that layer. This will
cause the layer to be reprojected along with the map. Is this what you
are trying to do?
You *may* have to save your mapfile, or your session, in order for it to
take effect, depending on your setup.
regards,
Jacob
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Stefan Schwarzer
Sent: 24 August 2006 13:45
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Mapscript Re-Projection
on-the-fly
Hey,
I can't imagine that such a question stays unanswered in the
mapserver community...
I meanwhile added a:
$map -> setProjection("init=epsg:26711");
to my code, but nothing happens - meaning: no error message but
no reprojection either.
Can anyone help me out?
Thanks in advance.
Stefan
On Aug 22, 2006, at 10:47 AM, Stefan Schwarzer wrote:
Gush,
I couldn't find any precise information about how to
re-project layers on-the-fly via PHP Mapscript. Here and there (via
MailingList and Google) bits and pieces, but altogether it didn't help
me a lot. Though I would have said that this is a basic question. But
perhaps too basic, so everbody finds out by himself?
So, can anyone let me know - giving a coding example -
how to re-project a mapfile on-the-fly from for example Lat/Long (global
view) to Lambert or Robin?
Thanks a lot for your help!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060824/4b90cb3d/attachment.html
