Improving documentation
Daniel Morissette
dmorissette at MAPGEARS.COM
Thu Aug 24 09:58:46 EDT 2006
Zenon Panoussis wrote:
> Talking about documentation, the projection EPSG:42304 in the example at
> http://mapserver.gis.umn.edu/docs/howto/wms_client/#adding-a-wms-layer
> is not in my proj-4.4.9 definition files. Probably a typo, but I have no
> clue what it should be instead, so I'm not touching the wiki.
The story about EPSG:42304 is explained in that same document at:
http://mapserver.gis.umn.edu/docs/howto/wms_client/#install-optional-proj4-epsg-codes
However, you're right that using a non-standard EPSG code in an example
is a bad idea so I have created a bug to ask the maintainer of the doc
to use EPSG:4326 (geographic lon/lat) in the examples instead:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1876
Daniel
Daniel Morissette
http://www.mapgears.com/
