zero vs null
Zenon Panoussis
oracle at PROVOCATION.NET
Thu Aug 24 14:58:07 EDT 2006
Rahkonen Jukka wrote:
> Reprojecting images one to one tends to give you those black
> edges because the original image boundaries does not match
> exactly the dimensions of pixels in the reprojected image.
> [...] a better approach to mosaic the original images before
> reprojection. If the original image is large enough to contain
> the resulting, reprojected image totally within its extents then
> the reprojected image will have no black pixels. Original images
> does not need to be mosaiced physically but an image catalogue,
> virtual layer, or how do you want to call can be used instead.
> If gdalwarp is to be used then GDAL/VRT virtual raster layer
> would is good for image source format. So your work chain would
> have one more step: after adding projection make a GDAL/VRT with
> a gdal_merge.py script modified for this purpose, and reproject
> and split that VRT layer to given extents by using gdalwarp with
> "-te" switch.
That looks like a better workaround than the one I'm currently using,
thanks. But should I also understand your reply to mean that there is
no way of telling gdalwarp to use NULL instead of 0 for the missing
pixels in a 1:1 reprojection?
Z
