Θέμα: Re: [UMN_MAPSERVER-USERS] Raster L ayer {Scanned} {Scanned} {Scanned}
    Siki Zoltan
    siki at AGT.BME.HU
    Wed Aug 23 02:49:31 PDT 2006
Please always cc your mail to the list, other members can have the same
problem.
Using gdalinfo you can display georeference data stored in geotif.
ddalinfo is a gdal utility tool, usually mapserver is built with gdal(ogr)
to handle different raster and vector formats.
I don't know what distribution you use. First check weather mapserver is
built with gdal :
mapserv -v
you should get something like this:
MapServer version 4.8.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
 OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPO
RTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPO
RTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SH
APEFILE DEBUG=MSDEBUG
If input=gdal is on the list, then gdalinfo is probably available on your
system. Depending on the operating system its path is different.
Start the command
gdalinfo your_tif_file
You will get an info page about your file check the corner coordinates
like this:
Driver: GTiff/GeoTIFF
Size is 3000, 2000
Coordinate System is `'
Origin = (647250.000000,234000.000000)
Pixel Size = (0.25000000,-0.25000000)
Metadata:
  TIFFTAG_SOFTWARE=Adobe Photoshop CS Windows
  TIFFTAG_DATETIME=2006:04:13 13:04:24
  TIFFTAG_XRESOLUTION=72
  TIFFTAG_YRESOLUTION=72
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Corner Coordinates:
Upper Left  (  647250.000,  234000.000)
Lower Left  (  647250.000,  233500.000)
Upper Right (  648000.000,  234000.000)
Lower Right (  648000.000,  233500.000)
Center      (  647625.000,  233750.000)
Band 1 Block=3000x1 Type=Byte, ColorInterp=Red
Band 2 Block=3000x1 Type=Byte, ColorInterp=Green
Band 3 Block=3000x1 Type=Byte, ColorInterp=Blue
You have a map file with an extent like this:
EXTENT 642000 225000 651000 234000
If the extent and the corners are not overlapping no tif data will be
displayed. May be the tif and the other  data are in different projection.
Bye
Zoltan
On Tue, 22 Aug 2006, K S wrote:
> Thanks for the feedback,
> I have a GeoTif image. This raster image was used in arcreader together with the rest data i now use with mapserver. how could it have wrong extent?
> Siki Zoltan <siki at AGT.BME.HU> Ýăńářĺ: Hi,
> It may be an extent or projection issue.
> Have you tried gdalinfo on your tif file?
> Is it a GeoTif or a tif with world file (twf)?
> Compare the extent got from gdalinfo and your mapexetent.
> Bye
> Zoltan
> > Hi everyone,
> >     I have a layer for a satellite photograph using this code:
> > # Chania aero layer
> >     LAYER
> >              NAME "CHQAero"
> >              DATA "CHQ1.tif"
> >              STATUS on
> >              TYPE raster
> >      END
> > everything seems to be ok.No error from mapserver.But nothing changes when  I turn on this layer.I can't see the photograph anywhere.I have used for testing another .tif image and it works.The .tif image CHQ1.tif  has been exported from arcView. Any ideas?
> > Thanks in advance
> >  ×ńçóéěďđďéĺßôĺ Yahoo!
> >  ÂáńĺčŢęáôĺ ôá ĺíď÷ëçôéęÜ ěçíý ěáôá (spam); Ôď Yahoo! Mail äéáčÝôĺé ôçí ęáëýôĺńç äőíáôŢ đńďóôáóßá ęáôÜ ôůí ĺíď÷ëçôéęţí ěçíőěÜôůí
> >  http://login.yahoo.com/config/mail?.intl=gr
More information about the MapServer-users
