how can I use 2 labelitems in the same layer
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Aug 24 20:41:37 EDT 2006
Luis Treviño wrote:
> Hi,
> I want to put 2 labels in a point layer. Is it possible to use 2
> labelitems in the same layer.
> How can I do that.
> Any ideas?
> Regards,
> Luis
Luis,
You might try something like:
LAYER
DATA "..."
CLASS
TEXT "[FIELD1]@[FIELD2]"
LABEL
WRAP '@'
END
END
END
In the example above, FIELD1 and FIELD2 would be the two items you want
to use as the two labels and I used '@' as a wrap character so the two
items will be on separate lines.
Another option would be to have an two layers using the same DATA and
position the label differently like UR and LR, but there is not
assurance that you won't get one of the labels and not the other because
of collisions.
-Steve W
