Map Filters
Randy How
rhow at I3.COM
Thu Aug 24 20:46:29 EDT 2006
Greetings,
I've been having unpredictable luck generating a map from MapServer 4.9
using "map filters" in the query string. I don't get an error, there's no
image produced or filename in the response.
Is there something wrong in the layer definition?
Is there something about the URL, specifically the syntax of the map filter
parameter?
Layer in Mapfile
LAYER
NAME "product"
CONNECTIONTYPE postgis
CONNECTION "user=uuuu password=xxxx dbname=ddddd host=m.m.m.m"
DATA "geometry from coverage"
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASS
OUTLINECOLOR 255 0 0
SYMBOL 1
SIZE 3
LABEL
TYPE bitmap
SIZE large
POSITION cc
COLOR 0 153 0
END
END
END
Works
http://development-1/development/webapplication/datadoors_1/MapServer2/mapse
rv.exe?
map=C:\Inetpub\wwwroot\development\webapplication\datadoors_1\ms_data\produc
t_coverage.map&
mode=browse&mapext=-128.10565 22.73085 -63.60935 50.65215
Does not work
rv.exe?
t_coverage.map&
mode=browse&mapext=-128.10565 22.73085 -63.60935 50.65215&
map_product_filter=product_id=1
Thanks
________________________________________________
Randy How
Geospatial Applications Developer
Rhow [at] i3.com
