[Fwd: Re: [UMN_MAPSERVER-USERS] how can I use 2 labelitems in
the same layer]
Luis Treviño
ltrevinoh at GMAIL.COM
Fri Aug 25 10:45:01 EDT 2006
Thanks Steve and Sebastian This is just what I needed.
Works OK. :-)
Regards,
Luis
2006/8/25, Stephen Woodbridge <woodbri at swoodbridge.com>:
> Right, that is what I get for not verifying the answer before I posted
> it. Thank you for the correction Sebastian.
> -SteveW
> -------- Original Message --------
> Subject: Re: [UMN_MAPSERVER-USERS] how can I use 2 labelitems in the
> same layer
> Date: Fri, 25 Aug 2006 11:01:13 +0200
> From: Sebastian Walter <sebastian.walter at fu-berlin.de>
> To: Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>
> References:
> <d7ba910a0608241727w5febb98ar7ed981a46abaf2b7 at mail.gmail.com>
> <44EE4741.8010304 at swoodbridge.com>
> Stephen Woodbridge wrote:
> > TEXT "[FIELD1]@[FIELD2]"
> ... doesn't work. You should use the notation ([FIELD1]@[FIELD2]),
> otherwise it's static.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060825/7b87b72f/attachment.html
