[Fwd: Re: [UMN_MAPSERVER-USERS] how can I use 2 labelitems in the
same layer]
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Aug 25 06:39:03 EDT 2006
Right, that is what I get for not verifying the answer before I posted
it. Thank you for the correction Sebastian.
-SteveW
-------- Original Message --------
Subject: Re: [UMN_MAPSERVER-USERS] how can I use 2 labelitems in the
same layer
Date: Fri, 25 Aug 2006 11:01:13 +0200
From: Sebastian Walter <sebastian.walter at fu-berlin.de>
To: Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>
References:
<d7ba910a0608241727w5febb98ar7ed981a46abaf2b7 at mail.gmail.com>
<44EE4741.8010304 at swoodbridge.com>
Stephen Woodbridge wrote:
> TEXT "[FIELD1]@[FIELD2]"
... doesn't work. You should use the notation ([FIELD1]@[FIELD2]),
otherwise it's static.
