Map Filters
Randy How
rhow at I3.COM
Fri Aug 25 13:30:43 EDT 2006
Steve,
That seems to work better. Would that explain inconsistency?
So, in general, be aware of reserved characters and replace them with escape
sequences.
I'll implement this and test it some more, and if it truly works I owe you
my sanity.
Thanks, Randy
-----Original Message-----
From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Sent: Friday, August 25, 2006 10:39 AM
To: Randy How
Subject: RE: [UMN_MAPSERVER-USERS] Map Filters
An = in a URL is a reserved character (as is a space) so you need to replace
those with escape sequences. Here's a page that seems to explain things
well.
http://www.blooberry.com/indexdot/html/topics/urlencoding.htm
Look at the reserved characters section. In short, your URL should read (I
think):
http://development-1/development/webapplication/datadoors_1/MapServer2/mapse
rv.exe?map=C:\Inetpub\wwwroot\development\webapplication\datadoors_1\ms_data
\product_coverage.map&mode=browse&mapext=-128.10565%2022.73085%20-63.60935%2
050.65215&map_product_filter=product_id%3D1
I could do WebEx late in the day if necessary.
Steve
>>> "Randy How" <rhow at i3.com> 8/25/2006 11:13:18 AM >>>
Steve, Thank for the reply,
Good question, and to continue the silliness, I'm not sure what properly
escaping the URL means. What's the proper escape character "/" or "'".
Adding the layer filter into the map file (good idea) and removing it in the
URL, yes that worked as expected.
I'm just very confused about this. I'm getting very inconsistent results,
different ways I'm attempting this. I'm been struggling with this since I'm
moved from MapServer 4.7.
I'm wondering if I can setup WebEx with you to show you the behavior and
discuss this with you, and start the resolution process with this issue.
It's driving me crazy. Please let me know if this is possible and when a
good time to setup a WebEx.
Thank you, Randy
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
On
Behalf Of Steve Lime
Sent: Friday, August 25, 2006 9:17 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Map Filters
In your second example (doesn't work), I'll ask a silly question. Are you
properly escaping the url- like the = in your filter?
One other idea, what happens if you put that filter in the mapfile instead
of passing it?
Steve
>>> Randy How <rhow at I3.COM> 8/24/2006 7:46:29 PM >>>
Greetings,
I've been having unpredictable luck generating a map from MapServer
4.9
using "map filters" in the query string. I don't get an error, there's no
image produced or filename in the response.
Is there something wrong in the layer definition?
Is there something about the URL, specifically the syntax of the map filter
parameter?
Layer in Mapfile
LAYER
NAME "product"
CONNECTIONTYPE postgis
CONNECTION "user=uuuu password=xxxx dbname=ddddd host=m.m.m.m"
DATA "geometry from coverage"
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASS
OUTLINECOLOR 255 0 0
SYMBOL 1
SIZE 3
LABEL
TYPE bitmap
SIZE large
POSITION cc
COLOR 0 153 0
END
END
END
Works
rv.exe?
map=C:\Inetpub\wwwroot\development\webapplication\datadoors_1\ms_data\produc
t_coverage.map&
mode=browse&mapext=-128.10565 22.73085 -63.60935 50.65215
Does not work
rv.exe?
t_coverage.map&
mode=browse&mapext=-128.10565 22.73085 -63.60935 50.65215&
map_product_filter=product_id=1
Thanks
________________________________________________
Randy How
Geospatial Applications Developer
Rhow [at] i3.com
