RASTER layer functionality, a SWAQ
John Novak
hetzerrr at GMAIL.COM
Sat Aug 26 03:40:17 EDT 2006
Excellent. Being lazy, I really appreciate solutions that require no coding
on my part. ;-)
I'll give these suggestions a try. Thanks.
JN
On 8/25/06, Paul Ramsey <pramsey at refractions.net> wrote:
> John,
> I think by following Frank's advice and using a PostGIS-hosted tile-
> index you can do a hell of a lot by manipulating your DATA statement
> to get the images you want for a given request. Things like temporal
> subsetting, etc, are all pretty easy. You don't even need to use
> mapscript, just override your DATA statement with a parameter in the
> mapserv CGI. (I think mapscript is largely irrelevant given the
> capabilities of the CGI system, personally.)
> Paul
> On 25-Aug-06, at 9:55 PM, Frank Warmerdam wrote:
> > John Novak wrote:
> >> I have a large number of rows containing metadata about rater
> >> files sitting in a PostGIS table. Each row is associated with a
> >> georeferenced file sitting in a file system, and the row contains
> >> polygon geometry representing the footprint of the raster. The
> >> rows also contain many other attributes that I'd like to use to
> >> filter the displayed rasters.
> >> Having the functionality of the RASTER layer, but using a PostGIS
> >> table as a source for features rather than a SHAPEFILE would be a
> >> very useful thing, at least in my case.
> >> What's the opinion regarding
> >> 1. the overall usefulness of such a beastie
> >> and
> >> 2. the complexity of actually implementing said beastie, given
> >> that it's a combination of the functionality of a PostGIS layer
> >> and a RASTER layer ?
> >> I admit I have not done my homework and really examined the code
> >> for these two layers.
> > John,
> > It is currently possible to use a postgis table as a "tile index" for
> > a raster layer. To do so, configure the postgis table as a
> > distinct layer,
> > and use the name of that layer in the TILEINDEX keyword of your
> > raster layer
> > instead of the name of an external shapefile.
> > The raster layer will do a spatial query on the tileindex table to get
> > a list of rasters to plot.
> > I'm a bit fuzzy on how you would do other sorts of query operations.
> > It is possible a FILTER on the tileindex layer will be preserved as
> > part of the tileindex query, but I'm not absolutely sure. Of course,
> > you could put complex query logic right into your DATA statement on
> > the postgis layer.
> > Best regards,
> > I set the clouds in motion - turn up | Frank Warmerdam,
> > warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | President OSGeo, http://
> > osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060826/39117e36/attachment.html
