Install on Suse 10.1
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Sun Aug 27 12:13:39 EDT 2006
Jacolin Yves wrote:
> Hi,
> your value for both --with-ogr an --with-gdal have to link to the same
> command :
> --with-ogr=/usr/local/gdal-1.3.2/bin/gdal-config
> --with-gdal=/usr/local/gdal-1.3.2/bin/gdal-config
Some what worked but now i am getting:
In file included from maptemplate.h:45,
from maptemplate.c:104:
map.h:386:21: error: ogr_api.h: No such file or directory
map.h:1712: error: expected ‘)’ before ‘hGeometry’
make: *** [maptemplate.o] Error 1
>> Matthew Perry wrote:
>>> Ryan,
>>> I noticed --with-ogr and --with-gdal point to different versions of gdal.
>>> Try pointing --with-gdal to your locally built gdal-config script
>>> (/usr/local/gdal-1.3.2/bin/gdal-config ??) and simply specifying
>>> '--with-ogr' without arguments.
>> Nope still no good, i tried using just --with-ogr and i got a different
>> error:
>> In file included from mapfile.c:146:
>> mapfile.c:151:24: error: cpl_conv.h: No such file or directory
>> mapfile.c:152:20: error: gdal.h: No such file or directory
>> when i tired to remove --with-ogr from the configure command i was still
>> left with
>> I did install gdal from an rpm that i found at :
>> http://www.gdf-hannover.de/media.php?id=1&lg=en
>> could maybe there be something wrong with that rpm? when i tired to
>> install it from the source i ran into missing library problems but the
>> rmp seemed to install fine and i can use all of the gdal commands from
>> the command line.
>>> On 8/27/06, Ryan Ollerenshaw <ollerery at engr.orst.edu> wrote:
>>>> I have been having all kinda of trouble installing mapserver on Suse
>>>> 10.1 i have been able to work though most of the errors but i am now
>>>> once again stuck. the configure command runs fine but when i do a make
>>>> i get the follow error:
>>>> I did a locate for gdal.h and cpl_conv.h and nothing.
>>>> Here is the configure that i am using:
>>>> ./configure \
>>>> --with-php=/usr/share/php-4.4.3 \
>>>> --with-proj=/usr/local/proj-4.4.9 \
>>>> --with-httpd=/var/www/bin/httpd \
>>>> --with-ogr=/usr/local/gdal-1.3.2 \
>>>> --with-gdal=/usr/bin/gdal-config \
>>>> --with-postgis=/usr/local/pgsql/bin/pg_config \
>>>> --with-curl-config=/usr/bin/curl-config \
>>>> --with-threads \
>>>> --with-geos=/usr/local/geos-2.2.1/tools/geos-config \
