Install on Suse 10.1
    Ryan Ollerenshaw
    ollerery at ENGR.ORST.EDU
    Sun Aug 27 10:12:48 PDT 2006
Jacolin Yves wrote:
> Hi,
> How do you have installed gdal-ogr ? with a binary or building it ?
> If you installed it with binary try to install libgdal1-devel as well
I installed gdal from an rpm following a link on the gdal page.  As your
advice i installed the gdal-devel rpm as well and now i am getting a new
error:
make: g++: Command not found
make: *** [mapogr.o] Error 127
thank you for all your help so far.
>> Jacolin Yves wrote:
>>> Hi,
>>> your value for both --with-ogr an --with-gdal have to link to the same
>>> command :
>>> --with-ogr=/usr/local/gdal-1.3.2/bin/gdal-config
>>>  --with-gdal=/usr/local/gdal-1.3.2/bin/gdal-config
>> Some what worked but now i am getting:
>> In file included from maptemplate.h:45,
>>                  from maptemplate.c:104:
>> map.h:386:21: error: ogr_api.h: No such file or directory
>> map.h:1712: error: expected ‘)’ before ‘hGeometry’
>> make: *** [maptemplate.o] Error 1
>>>> Matthew Perry wrote:
>>>>> Ryan,
>>>>> I noticed --with-ogr and --with-gdal point to different versions of
>>>>> gdal.
>>>>> Try pointing --with-gdal to your locally built gdal-config script
>>>>> (/usr/local/gdal-1.3.2/bin/gdal-config ??) and simply specifying
>>>>> '--with-ogr' without arguments.
>>>> Nope still no good, i tried using just --with-ogr and i got a different
>>>> error:
>>>> In file included from mapfile.c:146:
>>>> mapfile.c:151:24: error: cpl_conv.h: No such file or directory
>>>> mapfile.c:152:20: error: gdal.h: No such file or directory
>>>> when i tired to remove --with-ogr from the configure command i was still
>>>> left with
>>>> I did install gdal from an rpm that i found at :
>>>> http://www.gdf-hannover.de/media.php?id=1&lg=en
>>>> could maybe there be something wrong with that rpm? when i tired to
>>>> install it from the source i ran into missing library problems but the
>>>> rmp seemed to install fine and i can use all of the gdal commands from
>>>> the command line.
>>>>> On 8/27/06, Ryan Ollerenshaw <ollerery at engr.orst.edu> wrote:
>>>>>> I have been having all kinda of trouble installing mapserver on Suse
>>>>>> 10.1 i have been able to work though most of the errors but i am now
>>>>>> once again stuck. the configure command runs fine but when i do a make
>>>>>> i get the follow error:
>>>>>> I did a locate for gdal.h and cpl_conv.h and nothing.
>>>>>> Here is the configure that i am using:
>>>>>> ./configure \
>>>>>> --with-php=/usr/share/php-4.4.3 \
>>>>>> --with-proj=/usr/local/proj-4.4.9 \
>>>>>> --with-httpd=/var/www/bin/httpd \
>>>>>> --with-ogr=/usr/local/gdal-1.3.2 \
>>>>>> --with-gdal=/usr/bin/gdal-config \
>>>>>> --with-postgis=/usr/local/pgsql/bin/pg_config \
>>>>>> --with-curl-config=/usr/bin/curl-config \
>>>>>> --with-threads \
>>>>>> --with-geos=/usr/local/geos-2.2.1/tools/geos-config \
More information about the MapServer-users
