Install on Suse 10.1
Matthew Perry
perrygeo at GMAIL.COM
Sun Aug 27 14:20:03 EDT 2006
Ryan,
I noticed --with-ogr and --with-gdal point to different versions of gdal.
Try pointing --with-gdal to your locally built gdal-config script
(/usr/local/gdal-1.3.2/bin/gdal-config ??) and simply specifying
'--with-ogr' without arguments.
- matt
On 8/27/06, Ryan Ollerenshaw <ollerery at engr.orst.edu> wrote:
> I have been having all kinda of trouble installing mapserver on Suse
> 10.1 i have been able to work though most of the errors but i am now
> once again stuck. the configure command runs fine but when i do a make
> i get the follow error:
> mapfile.c:151:24: error: cpl_conv.h: No such file or directory
> mapfile.c:152:20: error: gdal.h: No such file or directory
> I did a locate for gdal.h and cpl_conv.h and nothing.
> Here is the configure that i am using:
> ./configure \
> --with-php=/usr/share/php-4.4.3 \
> --with-proj=/usr/local/proj-4.4.9 \
> --with-httpd=/var/www/bin/httpd \
> --with-ogr=/usr/local/gdal-1.3.2 \
> --with-gdal=/usr/bin/gdal-config \
> --with-postgis=/usr/local/pgsql/bin/pg_config \
> --with-curl-config=/usr/bin/curl-config \
> --with-threads \
> --with-geos=/usr/local/geos-2.2.1/tools/geos-config \
Matt Perry
perrygeo at gmail.com
http://www.perrygeo.net
