Install on Suse 10.1
Jacolin Yves
yjacolin at FREE.FR
Sun Aug 27 15:43:16 EDT 2006
How do you have installed gdal-ogr ? with a binary or building it ?
If you installed it with binary try to install libgdal1-devel as well
Regards,
Y.
Le Dimanche 27 Août 2006 18:13, Ryan Ollerenshaw a écrit :
> Jacolin Yves wrote:
> > Hi,
> > your value for both --with-ogr an --with-gdal have to link to the same
> > command :
> > --with-ogr=/usr/local/gdal-1.3.2/bin/gdal-config
> > --with-gdal=/usr/local/gdal-1.3.2/bin/gdal-config
> Some what worked but now i am getting:
> In file included from maptemplate.h:45,
> from maptemplate.c:104:
> map.h:386:21: error: ogr_api.h: No such file or directory
> map.h:1712: error: expected ‘)’ before ‘hGeometry’
> make: *** [maptemplate.o] Error 1
> >> Matthew Perry wrote:
> >>> Ryan,
> >>> I noticed --with-ogr and --with-gdal point to different versions of
> >>> gdal.
> >>> Try pointing --with-gdal to your locally built gdal-config script
> >>> (/usr/local/gdal-1.3.2/bin/gdal-config ??) and simply specifying
> >>> '--with-ogr' without arguments.
> >> Nope still no good, i tried using just --with-ogr and i got a different
> >> error:
> >> In file included from mapfile.c:146:
> >> mapfile.c:151:24: error: cpl_conv.h: No such file or directory
> >> mapfile.c:152:20: error: gdal.h: No such file or directory
> >> when i tired to remove --with-ogr from the configure command i was still
> >> left with
> >> I did install gdal from an rpm that i found at :
> >> http://www.gdf-hannover.de/media.php?id=1&lg=en
> >> could maybe there be something wrong with that rpm? when i tired to
> >> install it from the source i ran into missing library problems but the
> >> rmp seemed to install fine and i can use all of the gdal commands from
> >> the command line.
> >>> On 8/27/06, Ryan Ollerenshaw <ollerery at engr.orst.edu> wrote:
> >>>> I have been having all kinda of trouble installing mapserver on Suse
> >>>> 10.1 i have been able to work though most of the errors but i am now
> >>>> once again stuck. the configure command runs fine but when i do a make
> >>>> i get the follow error:
> >>>> I did a locate for gdal.h and cpl_conv.h and nothing.
> >>>> Here is the configure that i am using:
> >>>> ./configure \
> >>>> --with-php=/usr/share/php-4.4.3 \
> >>>> --with-proj=/usr/local/proj-4.4.9 \
> >>>> --with-httpd=/var/www/bin/httpd \
> >>>> --with-ogr=/usr/local/gdal-1.3.2 \
> >>>> --with-gdal=/usr/bin/gdal-config \
> >>>> --with-postgis=/usr/local/pgsql/bin/pg_config \
> >>>> --with-curl-config=/usr/bin/curl-config \
> >>>> --with-threads \
> >>>> --with-geos=/usr/local/geos-2.2.1/tools/geos-config \
Yves Jacolin
htp://yjacolin.gloobe.org
