Install on Suse 10.1
Jacolin Yves
yjacolin at FREE.FR
Sun Aug 27 16:35:01 EDT 2006
You need to install : gcc-c++.
Regards,
Y.
Le Dimanche 27 Août 2006 19:12, Ryan Ollerenshaw a écrit :
> Jacolin Yves wrote:
> > Hi,
> > How do you have installed gdal-ogr ? with a binary or building it ?
> > If you installed it with binary try to install libgdal1-devel as well
> I installed gdal from an rpm following a link on the gdal page. As your
> advice i installed the gdal-devel rpm as well and now i am getting a new
> error:
> make: g++: Command not found
> make: *** [mapogr.o] Error 127
> thank you for all your help so far.
> >> Jacolin Yves wrote:
> >>> Hi,
> >>> your value for both --with-ogr an --with-gdal have to link to the same
> >>> command :
> >>> --with-ogr=/usr/local/gdal-1.3.2/bin/gdal-config
> >>> --with-gdal=/usr/local/gdal-1.3.2/bin/gdal-config
> >> Some what worked but now i am getting:
> >> In file included from maptemplate.h:45,
> >> from maptemplate.c:104:
> >> map.h:386:21: error: ogr_api.h: No such file or directory
> >> map.h:1712: error: expected ‘)’ before ‘hGeometry’
> >> make: *** [maptemplate.o] Error 1
> >>>> Matthew Perry wrote:
> >>>>> Ryan,
> >>>>> I noticed --with-ogr and --with-gdal point to different versions of
> >>>>> gdal.
> >>>>> Try pointing --with-gdal to your locally built gdal-config script
> >>>>> (/usr/local/gdal-1.3.2/bin/gdal-config ??) and simply specifying
> >>>>> '--with-ogr' without arguments.
> >>>> Nope still no good, i tried using just --with-ogr and i got a
> >>>> different error:
> >>>> In file included from mapfile.c:146:
> >>>> mapfile.c:151:24: error: cpl_conv.h: No such file or directory
> >>>> mapfile.c:152:20: error: gdal.h: No such file or directory
> >>>> when i tired to remove --with-ogr from the configure command i was
> >>>> still left with
> >>>> I did install gdal from an rpm that i found at :
> >>>> http://www.gdf-hannover.de/media.php?id=1&lg=en
> >>>> could maybe there be something wrong with that rpm? when i tired to
> >>>> install it from the source i ran into missing library problems but the
> >>>> rmp seemed to install fine and i can use all of the gdal commands from
> >>>> the command line.
> >>>>> On 8/27/06, Ryan Ollerenshaw <ollerery at engr.orst.edu> wrote:
> >>>>>> I have been having all kinda of trouble installing mapserver on Suse
> >>>>>> 10.1 i have been able to work though most of the errors but i am now
> >>>>>> once again stuck. the configure command runs fine but when i do a
> >>>>>> make i get the follow error:
> >>>>>> I did a locate for gdal.h and cpl_conv.h and nothing.
> >>>>>> Here is the configure that i am using:
> >>>>>> ./configure \
> >>>>>> --with-php=/usr/share/php-4.4.3 \
> >>>>>> --with-proj=/usr/local/proj-4.4.9 \
> >>>>>> --with-httpd=/var/www/bin/httpd \
> >>>>>> --with-ogr=/usr/local/gdal-1.3.2 \
> >>>>>> --with-gdal=/usr/bin/gdal-config \
> >>>>>> --with-postgis=/usr/local/pgsql/bin/pg_config \
> >>>>>> --with-curl-config=/usr/bin/curl-config \
> >>>>>> --with-threads \
> >>>>>> --with-geos=/usr/local/geos-2.2.1/tools/geos-config \
Yves Jacolin
htp://yjacolin.gloobe.org
