Layer TYPE POINT ??????
Alejandro Rico
jarg58 at GMAIL.COM
Mon Aug 28 17:53:43 EDT 2006
Hi Eduardo!!
Maybe the error is in the extent of the map, are you sure that is the
correct?
On 8/28/06, Eduardo Arévalo <earevaloch at gmail.com> wrote:
> this he is to layer that I generate for the points of capitals:
> LAYER
> NAME estaciones
> TYPE POINT
> STATUS ON
> CONNECTION "user=postgres password=123456 dbname=sighco host=10.1.6.46port=5432"
> CONNECTIONTYPE postgis
> DATA "the_geom from estaciones_met_minag"
> #FILTER "nombre = 'huanuco'"
> CLASS
> NAME "estaciones"
> #TEMPLATE '/usr/local/apache2/htdocs/templates/hco_dep18.html'
> COLOR 217 231 62
> OUTLINECOLOR 89 93 188
> END
> END
> but when calling it with:
> http://10.1.7.233/cgi-bin/mapserv?map=/home/xxxxx/mapserver-4.8.3/tests/esta_minag.map&layer=estaciones&mode=map
> it does not leave anything to me or it gives no error me.
> please help.
Alejandro Rico
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060828/2cc82680/attachment.html
