Layer TYPE POINT ??????
    Eduardo Arévalo
    earevaloch at GMAIL.COM
    Tue Aug 29 07:18:49 PDT 2006
hello Alexander thanks for the suggestion revice extent and is the correct
one
2006/8/28, Alejandro Rico <jarg58 at gmail.com>:
> Hi Eduardo!!
> Maybe the error is in the extent of the map, are you sure that is the
> correct?
> On 8/28/06, Eduardo Arévalo < earevaloch at gmail.com> wrote:
> > this he is to layer that I generate for the points of capitals:
> > LAYER
> >   NAME estaciones
> >   TYPE POINT
> >   STATUS ON
> > CONNECTION "user=postgres password=123456 dbname=sighco host=10.1.6.46port=5432"
> > CONNECTIONTYPE postgis
> > DATA "the_geom from estaciones_met_minag"
> > #FILTER "nombre = 'huanuco'"
> >   CLASS
> >     NAME "estaciones"
> >     #TEMPLATE    '/usr/local/apache2/htdocs/templates/hco_dep18.html'
> >     COLOR 217 231 62
> >     OUTLINECOLOR 89 93 188
> >   END
> > END
> > but when calling it with:
> > http://10.1.7.233/cgi-bin/mapserv?map=/home/xxxxx/mapserver-4.8.3/tests/esta_minag.map&layer=estaciones&mode=map
> > it does not leave anything to me or it gives no error me.
> > please help.
> Alejandro Rico
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060829/a1acb104/attachment.htm>
More information about the MapServer-users
