Java Mapscript with Japanese Encoding
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Aug 30 03:13:45 EDT 2006
Mario,
Java mapscript should support international charsets, only make sure
that the environment when you start tomcat (or the servlet container
of your choice) is configured with the wanted locale.
Also note that LANG has lower precedence than the LC_* variables and
in particular check LC_ALL. For example if you set LANG=it_IT and
LC_ALL=en_US then the setting in effect is en_US.
There is an example using the german charset in the examples directory.
HTH,
Umberto
On 8/29/06, Mario Basa <mario.basa at gmail.com> wrote:
> Hello,
> I have been testing the java mapscript of mapserver-4.10-beta1 and it
> seems that layer.queryByAttributes only works with UTF-8 character
> encoded shape files and only if tomcat is started also in UTF-8
> (ja_JP.UTF-8) LANG environment.
> I tried using Shift_JIS encoded shape files (99% of all shape files
> here in Japan are Shift_JIS encoded) and tomcat restarted in UTF-8
> and then Shift_JIS LANG environments, but I couldn't get it to work
> anymore, as in layer.queryByAttributes can not match query items
> anymore with the data.
> Is there a work-around for this.
> Thanks.
> Mario.
