Variable Substitution
Fawcett, David
David.Fawcett at STATE.MN.US
Wed Aug 30 09:13:38 EDT 2006
On a normal MapServer CGI URL, I would suggest simply trying to add '&ctype=forest' to the end of your URL.
You are trying to do something different. You are trying to pass an expression to a WMS server. I would guess that you can
accomplish the same effect by using aStyled Layer Descriptor (SLD). Take a look at http://mapserver.gis.umn.edu/docs/howto/sldhowto
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Léveillé, James
Sent: Wednesday, August 30, 2006 7:25 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Variable Substitution
On the MapServer WebSite, there is an example on "Run-time Substitution" (http://mapserver.gis.umn.edu/docs/howto/runsub/?searchterm=parameter) that looks like this :
LAYER
NAME 'covertypes'
CLASSITEM 'type'
CLASS # highlighted presentation
EXPRESSION '%ctype%'
END
CLASS # default presentation
END
END
I would like to know if there is a way to specify the value of my '%ctype%' variable in a URL like this one :
http://myserver/mapserv.exe?map=mymapfile.map&Service=WMS&Version=1.0.0&Request=GetMap&Layers=mylayer1,mylayer2&SRS=epsg:xyz
Thanks.
Regards
James Léveillé
Intélec Géomatique
420, boul. Charest Est
Bureau 400
Québec (QC), Canada
G1K 8M4
Intélec Géomatique: 418.687.5000
MTQ: 418.380.2005 (#227)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060830/f04d9bd5/attachment.html
