Using MapServer with java on Windows OS
Francesco Martinelli
martinelli at PI.INGV.IT
Mon Dec 4 06:50:21 EST 2006
Dear friends,
I am trying to run a simple demo of MapServer using Java
on a Windows XP Professional operating system, but unsuccesfully.
Is anyone working on this system and using java with MapServer,
or knowing of any issue I should work around before going ahead?
Below are some of the details of my test, but please ask if I missed
something could be usefull.
Thank you for any help,
Francesco.
I am using the package "ms4w_1.5.1.zip".
The demo program is very basic:
import edu.umn.gis.mapscript.mapObj;
public class DemoMain {
private mapObj _map = null;
public DemoMain() {
try {
String mapFile = "tutor.map";
_map = new mapObj(mapFile);
catch (Throwable ex) {
ex.printStackTrace();
public static void main(String[] args) {
try {
DemoMain test = new DemoMain();
} catch (Throwable ex) {
Now I compiled it succesfully, then I copied the "dll" files I identified
as necessary starting from mapscript.dll (using "depender.exe") in the
"TestUML" subdirectory and then run the program.
The files in TestUML are:
-) bgd.dll
-) gdal13.dll
-) geotiff.dll
-) iconv.dll
-) libcurl.dll
-) libecwj2.dll
-) libmap.dll
-) libmysql.dll
-) libpg.dll
-) libtiff.dll
-) mapscript.dll
-) pdflib.dll
-) proj.dll
-) xerces-c_2_7.dll
-) zlib1.dll
The command line to run the program is:
>java -classpath .\;.\mapscript.jar -Djava.library.path=.\TestUML\ DemoMain
The result was:
1) An error window reporting that "bgd.dll" was not found
2) the following lines after the command line:
java.lang.UnsatisfiedLinkError: C:\Demo\TestUML\mapscript.dll: Can't find
dependent libraries
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at edu.umn.gis.mapscript.mapscriptJNI.<clinit>(mapscriptJNI.java:22)
at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:312)
at DemoMain.<init>(DemoMain.java:9)
at DemoMain.main(DemoMain.java:20)
Thank you again for your time,
Francesco.
