map a search: best strategy?
John Smith
jayzee.smith at GMAIL.COM
Mon Dec 4 18:16:29 EST 2006
On 12/4/06, Hal Mueller <hal at mobilegeographics.com> wrote:
> In your first message it sounded like you had a collection of
> locations that didn't change very often.
> If that's true, why are you geocoding on the fly? (and if not, then
> I didn't understand at all).
you're right. the search database doesn't change much but it's maintained by
someone else. if nothing looks good i'd have to tell him- dude add x/y
column, but something tells me it's not as cool.
> First, create a master shapefile with all of the possible search
> result locations, with a unique ID for each point.
> Your search DB returns a result that says "display unique ID's 1, 2,
> 5, 216, and 37".
> You create a .DBF file with this schema:
> UNIQUEID, DISPLAY
> UNIQUEID would be the same as the unique point identifier in the
> master shapefile.
> The contents of the dynamic .DBF would be:
> 1, 1
> 2, 1
> 3, 0
> 4, 0
> 5, 1
> 6, 0
> 36, 0
> 37, 1
> 38, 0
> 216, 1
> and so on--1 if the point is to be displayed, 0 if not
> Now you could copy the other component files from your master
> shapefile to the dynamic one. But instead, just make a symbolic link
> to the spatial data parts.
sweet. let's see if i get this right-
1 external server does the search and says "show blah blah"
2 my internal server already has a shp as base layer showing all the
geocoded points. i simply create another dbf, do a join and overlay that to
show "blah blah"? (didn't quite get symbolic link. join?)
can a smart wms also help here?
jzs
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061204/2cf5133d/attachment.html
