Can I simply change UNITS and EXTENT in PROJECTION?
mark at deblois.nl
mark at DEBLOIS.NL
Thu Dec 7 04:37:45 EST 2006
Hi all!
My mapfile successfully outputs a map in Winkel Triple projection using
the parameters below. Extent BBOX units are in meters as this is what the
projection seems to output.
What I would like to do is change the units to DD and set the EXTENT to
-180 -90 180 90 (world view DD) but when I do so I get an empty map. Can
anyone tell me if what I am trying is possible? And if so what I am
missing (perhaps the obvious)?!
Thanks for your help.
cheers,
Mark
PROJECTION
"proj=wintri"
"ellps=WGS84"
"lat_1=50"
"datum=WGS84"
"units=m"
# this is what I'd like it to be in "units dd"
END
SIZE 600 400
EXTENT -20000000 -11000000 20000000 11000000
# this is what I'd like it to be in EXTENT -180 -90 180 90
