Java with MapServer on Projection
Francesco Martinelli
martinelli at PI.INGV.IT
Thu Dec 7 06:33:37 EST 2006
Dear friends,
I am trying to use the PROJECTION section in a map file using MapScritpt
via Java on Windows.
The map file is very basic, and when using the map file reported below the
program works fine; if I uncomment the three lines about PROJECTION I have
the following error:
Exception in thread "main" java.lang.UnknownError: No such file or directory
at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:312)
at Demo.Main.<init>(Main.java:10)
at Demo.Main.main(Main.java:16)
Java Result: 1
I "suspect" the reason is some unreacheable file or directory used by the
proj.dll (??), however the PATH include C:\ms4w\Apache\cgi-bin (where
proj.dll is located whith the distribution package).
The map file is the following (and it works if used via PHP !!):
MAP
IMAGETYPE PNG
EXTENT 126500 3907000 1521500 5302000
UNITS METERS
SIZE 600 600
IMAGECOLOR 230 230 90
TEMPLATEPATTERN "itasca"
LAYER
NAME "areas"
CONNECTIONTYPE postgis
CONNECTION "user=DBroot password=root dbname=s1 host=127.0.0.1 port=5432"
DATA "the_geom FROM (SELECT * FROM aree_geografiche ORDER BY tipo_area
DESC) AS confini USING UNIQUE gid"
TYPE POLYGON
STATUS ON
# PROJECTION
# "init=epsg:32632"
# END
CLASS
NAME "States"
STYLE
WIDTH 3
COLOR 194 194 194
OUTLINECOLOR 0 0 0
END
END
END
END # Map File
Thank you,
Francesco.
