questions about setting up SOS
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Sun Dec 17 12:35:56 EST 2006
Sorry I missed this e-mail.
yes the 2 layers should be defined. Plus I think you need to define the
sos_[item name]_componenturl where item_name is the attribute name in
your data that contains the values of what is measured. So your 2 layers
should have each a sos_[item name]_componenturl pointing to the
temperature and salinity fields. Those values will be returned when
doing a GetObervation request.
Later,
Jeff McKenna wrote:
> (SOS people on the list can correct if I'm wrong...)
> I think they answer is yes, define 2 layers each with their own
> observedproperty_id.
> jeff
> John Cartwright wrote:
>> Hello All,
>> I'm trying to understand how to configure a mapfile to serve data out
>> of Oracle Spatial using Mapserver's SOS_SERVER and am a little
>> confused about the relationship between the sos_procedure,
>> sos_observedproperty_id, and sos_offering_id.
>> It looks like the sos_procedure and sos_observedproperty_id must be
>> unique to each layer in the mapfile. So if I have a system of buoys
>> that each measure temperature and salinity, would I define two layers
>> pointing to the same spatial data and sharing the same sos_offering_id
>> value?
>> Thanks!
>> -- john
>> LAYER
>> NAME observations_tmp
>> METADATA
>> "sos_procedure" "tmp"
>> "sos_offering_id" "argo"
>> "sos_observedproperty_id" "ztmp"
>> "sos_describesensor_url" "http://some/url/"
>> END
>> TYPE point
>> DATA buoy.shp
>> END
>> LAYER
>> NAME observations_sal
>> METADATA
>> "sos_procedure" "sal"
>> "sos_observedproperty_id" "zsal"
>> END
>> TYPE point
>> DATA buoy.shp
>> END
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
