set point symbol size
tom
tom at GISAPPS.COM.HK
Mon Dec 11 21:39:49 EST 2006
Dear All
I would like to know whether it is possible to set point symbol size dynamically. For example, I can create a size value as a parameter and pass to mapserv.exe. Since I am not using mapscript, so are there any simple way to do that?
I have tried the mapfile as follow, it is not work and parsing error is returned, unfortunately.
LAYER
NAME TMP
TYPE POINT
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource><OGRVRTLayer name='TMP'>
<SrcDataSource>ODBC:POINT</SrcDataSource>
<SrcSQL>SELECT X,Y FROM TMP</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS></LayerSRS>
<GeometryField encoding='PointFromColumns' x='x' y='y'/>
</OGRVRTLayer></OGRVRTDataSource>"
DATA "TMP"
CLASS
SYMBOL 'circle'
size %SIZE%
COLOR 0 0 255
OUTLINECOLOR 128 128 128
END
END
Thanks for help.
Regards,
Tom
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061212/8b41d712/attachment.html
