Changing Output Projection
Bill Thoen
bthoen at GISNET.COM
Thu Dec 21 15:40:55 EST 2006
I'm pulling a polygon layer from Postgis and displaying it in MapServer,
but I can't seem to change the output projection. The polygon layer's
native coordinate system is WGS84, and when I check MapServer with th
e-v switch it says it supports PROJ. The unprojected map displays fine
if I use decimal degrees, but it seems to be ignoring my PROJECTION
settings the map file. Can someone tell me what's wrong? Here's the map
file:
MAP
SIZE 600 600
# EXTENT -125 35 -66 50
EXTENT -300000 -100000 300000 100000
IMAGECOLOR 180 180 250
UNITS METERS
PROJECTION
"proj=utm"
"ellps=GRS80"
"datum=NAD83"
"zone=15"
"units=m"
"north"
"no_defs"
END
WEB
TEMPLATE counties.html
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/tmp/"
END
LAYER
NAME counties
TYPE POLYGON
STATUS DEFAULT
CONNECTION "user=*** password=*** dbname=spatial1 host=localhost
port=5432"
CONNECTIONTYPE POSTGIS
DATA "the_geom from counties"
LABELITEM 'county'
LABELMAXSCALE 5000000
CLASSITEM 'county'
CLASS
NAME 'US Counties'
OUTLINECOLOR 100 100 100
COLOR 255 255 204
LABEL
SIZE LARGE
COLOR 0 0 255
OUTLINECOLOR 255 255 255
MINFEATURESIZE 10
END
END
PROJECTION
"proj=utm"
"ellps=GRS80"
"datum=NAD83"
"zone=15"
"units=m"
"north"
"no_defs"
END
END
END
