[UNCLASSIFIED]RE: [UMN_MAPSERVER-USERS] Mapscript with php as apa
che module
Antti Roppola
Antti.Roppola at BRS.GOV.AU
Thu Dec 21 17:39:13 EST 2006
Hi Antonio,
Did you get a definitive answer on this? I am about to build a new server and
have been looking through the mailing list and various doco to see if
the improvements to threading makes it OK to use PHP as a module.
The setup section from the PHP Mapscript howto (late 2005) implies that CGI
is only required for Windows installs, but the FAQ at the end says CGI is a must:
http://mapserver.gis.umn.edu/docs/howto/phpmapscript-install/#setting-up-php-on-your-server <http://mapserver.gis.umn.edu/docs/howto/phpmapscript-install/#setting-up-php-on-your-server>
These bugzilla entries suggests that DSOs are OK from 4.6.1 onwards
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=349 <http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=349>
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1322 <http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1322> (note comment #30 from Daniel)
Antti
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Antonio Grassi
Sent: Wednesday, 6 December 2006 3:46 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Mapscript with php as apache module
Hi all. I've been looking in the mailing list and reading the documentation, but it is not clear to me, if there still exist problems when using php-mascript with php built as an apache module. Does anyone have a clear idea about this?
Thanks very much,
Antonio
IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061222/88b6303e/attachment.html
